2010 Hyosung GV250 Stator Casing Removal
alanq35
Real Name: Alan James
Years Riding: 3
My Motorcycle: 2010 Hyosung GV250
#1 Unread post by alanq35 »
Does anyone know how to remove the stator casing off of my Hyosung GV250? I removed all the 8mm bolts but casing still will not come off. Thx
Re: 2010 Hyosung GV250 Stator Casing Removal
#2 Unread post by Johnj »
Hello Alan and welcome to the forum. Well, I haven't ever worked on a Hyosung before but it's all the same. Are you sure you got all the fasteners loose or out? Did you make sure the footpegs aren't in the way? Have you tried tapping on the case with a plastic, rawhide, or rubber mallet(do not use a hammer)? The old gasket may have created a seal. Let us know anyway. Good luck.
#3 Unread post by Wrider »
Yup, what JohnJ said. A lot of times they're pretty hard to remove because the old gasket has created a seal of sorts, plus the magnetic attraction keeps it on there pretty hard.
alanq35
Years Riding: 3
#4 Unread post by alanq35 »
Thank you both for your replies. I will probably need to use more force then i was as i was cautious to not crack anything. I will let ya know how it goes...
