CM450E clutch adjustment
Posted: Thu Aug 04, 2005 5:20 am
by rusbus
I have an '83 Honda CM450E.
I'm having trouble figuring out the clutch adjustment. I can adjust it down until it's as tight as possible (bare minimum of freeplay), but I still hear a THUNK when shifting from neutral to 1st, and the bike jerks a bit. Is this normal? Initially I thought I might need to tighten the clutch cable, but it's not helping...
Posted: Thu Aug 04, 2005 10:29 am
by TechTMW
That's normal. Almost every older bike has that and most new ones too!
Posted: Thu Aug 04, 2005 2:00 pm
by kar_the_terrible
Aye I get that a lot too.. Just learned to live with it. However, I tend to get the occasional false neutral, while shifting gears. In which case I have to shift again with a little more "assertiveness" and the gear seats right.
I wonder if this is just age or does the gearbox need a peek inside??
K
