2013 Beta Evo 300 4 Stroke - Coolness Factor = 66.8%
Posted: Fri Jul 05, 2013 10:57 am
2013 Beta Evo 300 4 Stroke on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... Stroke.htm
The Beta Evo 300 4 Stroke models lead the way in performance and ease of use. With their “in house” manufactured 4-valve liquid cooled motors to the famous Single Box aluminum frame, the new 2013 Evo thumpers are ready for the toughest sections or just cow-trailing along the mountains. These models come with an incredibly quiet muffler. Also available is the popular long-range tank/seat combo for extended trail rides. This set up provides two gallons of fuel for roughly a 50 mile range.
Easy to ride, Easy to start, Easy to live with!
WHAT IS Mototrial?
If you have never ridden a modern trials bike, you simply don’t know what you’re missing. The ability to negotiate rough terrain is unmatched by anything on two wheels, but the real secret is how much fun they are to ride! The combination of light weight (150 lbs), incredible low-speed handling, very quiet, and a torquey engine allow them to go practically anywhere with ease. Not only will you have fun, but you’ll experience new places to ride, meet new friends and learn new skills that will take you to the next level of motorcycling. Intrigued? You should be.
2013 Beta Evo 300 4 Stroke - Total Motorcycle USA Specifications/Technical Details
Total Motorcycle MSRP Price: $7999.00 USD
Engine
Type: Single cylinder, 4-stroke, 4-valve, liquid-cooled
Bore: 77mm
Stroke: 53.6mm
Displacement: 249.6 cc
Compression Ratio: 11:5:1
Ignition: Electronic 12 volt, 85 watt w/ dual-map switch (aggressive or soft settings)
Spark Plug: NGK CR7EB
Lubrication: Internal oil pump w/ cartridge filter
Carburetor: Mikuni CV TMW
Clutch: Wet multi-disc w/ cush-drive basket
Transmission: 5-speed
Chassis
Frame: Aluminum Single Box Frame w/ built in fuel tank
Wheelbase: 51.4”
Seat Height: 26”
Ground Clearance: 12.2”
Footrest Height: 13.6”
Dry Weight: 156.5 lbs. dry
Fuel Tank Capacity: .7 US gallons
Front Suspension: 38mm Paioli TMW
Rear Suspension: Single shock, aluminum bodied including linkage, adjustable dampening
Front Wheel Travel: 6.5”
Rear Wheel Travel: 7.1”
Final Gearing: 11t front, 41t rear
Front Brake: 185mm rotor w/ 4-piston caliper
Rear Brake: 160mm rotor w/ twin-piston caliper
Front/Rear Rim: 21” (Front) 18” (Rear)
Front/Rear Tire: Michelin Trial
Warranty: 6 month Limited Warranty
Total Motorcycle MSRP: $7999.00
WHAT IS Mototrial?
Engine
Bore: 77mm
Stroke: 53.6mm
Chassis
Wheelbase: 51.4”
Seat Height: 26”
