Swift electrical problems
Posted: Sat Jul 06, 2013 8:27 am
by SOS bign
Ok I got a 2008 swift lucky strike. It seems to have an electrical issue since the day I bought it. I ride it then it just shuts down. Let the bike sit and it will restart and run for who knows how long. I know the circuit breaker pops then resets but also has some other box with what appears to be a relay and flat resistors or something. Never seen a set up like this before and need help.
Re: Swift electrical problems
Posted: Sat Jul 06, 2013 3:35 pm
by Johnj
Hello Richard and welcome to the forum. I got to ask, have you tried removing the gas cap when it dies to see if the gas tank has a vacuum building up in it. The condition you're describing sounds like a vacuum lock which occurs when the tank vent is blocked. I could be wrong though.
Posted: Sat Jul 06, 2013 5:54 pm
by SOS bign
Yes have run with cap loose. Like I mentioned when it dies and you sit for a few minutes you hear the circuit breaker reset. I have changed the breaker out and it still does it. I can not find a wiring diagrams for any swift motorcycle on the Internet therefore I'm not sure which wires to start chasing for a short.
Posted: Sat Jul 06, 2013 6:16 pm
by Johnj
OK well we'll make you a circuit diagram. You've got a battery, a charging circuit (alternator and regulator), an ignition circuit, and a lighting circuit. Do you know which breaker is tripping?
Posted: Sun Jul 07, 2013 7:17 am
by SOS bign
It only has one breaker. It is running off the ignition. One side comes in from battery other side goes out to a box that has what appears to be a relay and some flat resistors and like 5 led lights. Also appears to run to ignition module under nose cone. This is the weirdest setup I have ever seen
Posted: Sun Jul 07, 2013 7:57 am
by Johnj
Do you have a Digital Voltage Meter? Can you remove your key switch without removing any of the wires?
