81 Honda CM400 Issue. Help me out!
Posted: Sun Jul 14, 2013 9:57 am
I Purchased an 81 Honda CM400 for cheap. It didn't run at the time however I took the carbs out cleaned them and replaced every part or seal that was damaged. I also blew out all the jets with compressed air so I can see light through every jet or hole or feel compressed air rushing through. Everything seems to be in working order. After every thing was done it started right up. I tuned the carbs to the Bike manuals specs and there was no delay when I hit the throttle.
The thing is that it idles right but every time I ride it more than a few blocks it dies on me and won't start up or idle with out the choke on max and it does not stay running for long. After that it will not turn over for 15 or 20 min. Both carbs seem to be getting fuel just fine. If I try and ride it now, giving it any throttle kills the bike. Since then I've taken out the carbs again. It looks fine....
Any ideas?
<------- Vader is the CM400 and I'm the yellow guy in this situation..
Any ideas?
