1975 hondaXL 250 Rattles and smokes
TAK
My Motorcycle: 1975 Honda XL 250
#1 Unread post by TAK »
I have a 1975 Honda xl 250 and it rattles and produces greyish white smoke that wont go away, I have been been told that the rattling is normal, but I don't think so. is it my valves? or is there something else?
Re: 1975 hondaXL 250 Rattles and smokes
#2 Unread post by Johnj »
Sounds like you need to rebuild the engine.
GS_in_CO
Real Name: Ron
#3 Unread post by GS_in_CO »
Did you buy it in this condition?
Is this a resurrection after sitting for 20 years?
Was it parked because it was doing this?
Did you find it in a junk heap?
Did you put oil in the cylinders when you prepared to start it up?
Did somebody before you do that?
Did you put fresh fuel in it? Could it be old fuel that someone might have mixed oil into thinking it was a 2-stroke?
Rattling could be most anything. Get a service manual.
Start with looking into how the cam chain is tensioned.
Then see how to adjust the valves.
Then see if you can check compression.
BTW- oil smoke is blue, unburned fuel (too rich mixture) is black, gray smoke is usually coolant but in your case it's air cooled so....... you probably should check the smoke color again. Well, condensation of exhaust into cold air is white but could look gray. So if it's cold where you are and the engine is cold you might get a steam cloud.
If you have the time to work thru the issues this will be a good learning experience. (believe it or not)
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
TAK
#4 Unread post by TAK »
I have corrected the valves and still have the same problem. the smoke is a greyish white, and it will go away after riding it for a while, but when I stop the smoke starts to slowly build back up when the RPMs return to an idle.
GS_in_CO
Real Name: Ron
#5 Unread post by GS_in_CO »
TAK wrote:I have corrected the valves and still have the same problem. the smoke is a greyish white, and it will go away after riding it for a while, but when I stop the smoke starts to slowly build back up when the RPMs return to an idle.
Possibly valve guides/valve stem seals.
High vacuum at idle pulls oil thru the worn/hard seals.
(Or it's a Ford V8 and the head is badly sludged.....)
Smoke is probably blue if you get the light just right.
Or it's gas that someone thought needed some oil in it because they thought the bike is a 2 stroke.
Ron
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
