1993 Kawasaki Vulcan running oddly
Posted: Thu Aug 29, 2013 7:03 pm
Hello,
I have a 1993 Kawasaki Vulcan 750 that I picked up about a month ago. It had 25k miles and was running absolutely perfect. Then the stator went out. For those of you who don't know, replacing the stator requires removing the engine. I replaced the stator and put the bike back together. It starts fine, charges fine, but now it doesn't like to rev past 5000 RPM. Sometimes it will but not all the time. Also when riding it, it feels as though it's missing on one cylinder randomly. I'll hit the gas, kind of sit there for a few seconds, then it will take off. Or I'll hit the gas, it will accelerate for a few seconds, then it will hesitate for a few seconds. After first starting the bike, it seems to idle fine but any throttle will kill it.
There are no vacuum leaks, no fuel leaks, no oil leaks. I rebuilt the carbs, I have spark on all four plugs, the plugs look as though the fuel mixture is fine. I think it has to be an ignition problem. Based on the fact that it was running well before the stator went out, it had to be something I did to cause this problem. I'm completely lost as to what it may be though. Any help would be greatly appreciated.
Thanks!
Thanks!
