2012 KTM 990 Duke R - Coolness Factor = 78.3%
Posted: Fri Sep 06, 2013 7:34 am
2012 KTM 990 Duke R on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... 0DukeR.htm
2012 KTM 990 Duke R
THE ALPHA ANIMAL
The totally single-minded "R" version of the Super Duke is the flagship model of KTM's Naked Bike range in MY2012. Rated at a plentiful 125hp, the newly homologated LC8 V-twin engine delivers a solid punch and incomparable liveliness. The sharper trellis frame makes for maximum agility with its sporting “R” geometry and only nine kilograms of weight. The special “R” chassis ensures a high-resolution feedback about the road surface with its precisely adjustable WP steering damper and top quality suspension components.
First rate equipment like the machined, black anodized triple clamps, radial brake and clutch levers or the high quality Brembo brakes with radial four-pot front callipers elevate this Superbike among the Naked Bikes and ensure intuitive operation. Massive
power and perfect control right up to the limit make the 990 Super Duke R the ultimate nemesis of hypersport bikes on race tracks. And not just there. Weightless agility, incisive precision and an optimised suspension set-up let the "R" score on public roads, too. A
riding experience that can now be shared, thanks to the new dual seat. For a Duke rarely comes alone.
2012 KTM 990 Duke R - Totalmotorcycle.com International Specifications/Technical Details
MSRP Price: See KTM dealer for pricing.
ENGINE
Engine type: 2-cylinder, 4-stroke, V 75°
Displacement: 999 cc
Bore/stroke: 101/62.4 mm
Power: 92 kW (125 hp) @ 9000 rpm
Torque: 100 Nm @ 8000 rpm
Compression ratio: 11.5:1
Starter/battery: Electric starter/12V 11.2Ah
Gears: 6 gears
Fuel system: Keihin electronic fuel injection
Control: 4 V/DOHC
Lubrication: Pressure lubrication with 2 Eaton pumps
Engine oil: Motorex, SAE 10W-50
Primary drive: 35:67
Final drive: 16:38
Cooling: Liquid cooling
Clutch: Wet multi-disc clutch, hydraulically operated
Engine management/ignition: Keihin EMS
CHASSIS
Frame: Chromium-Molybdenum trellis frame, powder-coated
Subframe: Aluminium
Handlebar: Aluminium, tapered, Ø 28/22 mm
Front suspension: WP-USD Ø 48 mm
Rear suspension: WP-Monoshock
Suspension travel front/rear: 135/150 mm
Front brake: 2 x Brembo four piston, radially bolted caliper, brake disc Ø 320 mm
Rear brake: Brembo single piston, floating caliper, brake disc Ø 240 mm
Wheels front/rear: Cast aluminium wheels 3.50 x 17''; 5.50 x 17''
Tires front/rear: 120/70 ZR 17; 180/55 ZR 17
Chain: X-Ring 5/8 x 5/16"
Silencer: Stainless steel silencer with regulated catalytic converter
Steering head angle: 67.3°
Trail: 93.9 mm
Wheel base: 1,450 ± 10 mm
Ground clearance: 150 mm
Seat height: 850 mm
Tank capacity: approx. 18.5 litres/3.5 litres reserve
Weight (ready to race): approx. 186 kg (without fuel)
2012 KTM 990 Duke R
THE ALPHA ANIMAL
ENGINE
Gears: 6 gears
Control: 4 V/DOHC
Final drive: 16:38
CHASSIS
Subframe: Aluminium
Trail: 93.9 mm
Seat height: 850 mm
