2014 Yamaha FJR1300ES - Coolness Factor = 78.4%
Posted: Sat Sep 28, 2013 7:14 am
2014 Yamaha FJR1300ES on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... 1300ES.htm
New for 2014:
2014 Yamaha FJR1300ES on Totalmotorcycle.com
Supersport touring perfected –The new FJR1300ES offers all the same sporty luxury of the standard FJR but with the addition of electrically adjustable suspension...
Nothing but the Best.
The 2014 Yamaha FJR1300ES features advanced ABS, electronic adjustable windscreen, heated grips and now offers electronically adjustable suspension so you can dial in your ride with a simple push of a button. The 2014 FJR also features D-mode (Drive-Mode) for varying throttle mappings that provide exceptional versatility. This works in conjunction with TCC-T (Yamaha Chip Controlled Throttle) and the intake/exhaust system, generating engine character that can be sportier or more relaxed dependingo nthe riding situation.
2014 Yamaha FJR1300ES Totalmotorcycle.com Key Features
•The FJR1300ES features an all-new electronically adjustable suspension to take the bother out of adjusting the suspensions to fit different riding conditions and bring greater convenience to touring.
•The new 2014 FJR1300ES offers the same aggressive styling features, including the headlight cowl and side fairing as the FJR1300A. The flexible side panels are not only great looking, they also adjust to help improve comfort and aid in weather protection.
•FJR1300ES riders can select D-mode (Drive-mode) for varying mappings, giving the motorcycle exceptional versatility. This works in conjunction with YCC-T® (Yamaha Chip Controlled Throttle) generating engine character that can be sportier or more relaxed depending on the riding situations.
•Traction control developed from MotoGP® technology is standard on the FJR1300ES. While engaged, the system detects wheel spin and adjusts ignition timing, fuel injection volume, and throttle valve opening to help maintain traction, unlike some competitors who’s system only cuts ignition creating a hard cut-out feeling. The system is designed to let the operator ride on roads that have limited traction with more confidence.
•Another popular feature standard on the FJR1300ES is cruise control. Riders can set cruising speed with the push of a button on the left handlebar to provide comfort and ease on extended road trips.
•A three-part instrument panel provides riders with all the information they need while enjoying the road. Riders can easily customize the display to show the information they want.
•The front brake lever activates six of the eight front braking pistons; the rear brake pedal activates two rear pistons and the other two front pistons — provides balanced anti-lock braking in all conditions.
•A pushbutton-adjustable windscreen and a thick comfy seat for two are perfect for comfortable, long-distance riding and come standard on the FJR1300ES.
•Additional features on the 2014 FJR1300ES include a two-position adjustable rider seat, low for shorter riders or nearly 1-inch higher for a more spacious feel for taller riders, plus handlebars that can be adjusted to one of three different positions. The result is a superb, custom-fit ride.
2014 Yamaha FJR1300ES - Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $16,890 (Candy Red) Available from November 2013 USD
Canada MSRP Price: $18,499.00 CDN (named FJR1300E in Canada)
Engine
Type 1298cc liquid-cooled inline 4-cylinder; DOHC, 16 valves
Bore x Stroke 79.0 x 66.2mm
Compression Ratio 10.8:1
Fuel Delivery Fuel Injection
Ignition TCI: Transistor Controlled Ignition
Transmission 5-speed; multiplate wet clutch
Final Drive Shaft
Chassis
Suspension / Front 43mm upside down forks with electronic adjustment; 5.3-in travel
Suspension / Rear Single shock; electronically adjustable suspension: 4.9-in travel
Brakes / Front Dual 320mm disc, UBS ABS
Brakes / Rear 282mm disc, UBS ABS
Tires / Front 120/70-ZR17 radial
Tires / Rear 180/55-ZR17 radial
Dimensions
Length 87.8 in
Width 29.5 in
Height 52.2 or 57.3 in
Seat Height 31.7 or 32.5 in
Wheelbase 60.8 in
Ground Clearance 4.9 in
Rake (Caster Angle) 26°
Trail 4.3 in
Fuel Capacity 6.6 gal
Fuel Economy** 36 mpg
Wet Weight*** 644 lb / CAL 646 lb
New for 2014:
Engine
Final Drive Shaft
Chassis
Dimensions
Length 87.8 in
Width 29.5 in
Wheelbase 60.8 in
Trail 4.3 in
