2000 honda shadow sabre 1 lugging
Posted: Tue Oct 15, 2013 9:04 am
by gosthrider82
does any body have any idea's as to why a 2000 honda shadow sabre 1100 would be driven down the open road at 55 mph. then start 1 lungin. if you keep riden it while 1 lungin the battery dies. if you stop on the side of the road shut the bike off and then turn the key on and start the bike it's fine. it got clean air filter,new spark plugs and good fuel. any ideas
Re: 2000 honda shadow sabre 1 lunging
Posted: Tue Oct 15, 2013 9:57 pm
by dr_bar
My guess would be that your not charging the battery at the proper rate. With that said, I'm no mechanic...
Posted: Tue Oct 15, 2013 11:26 pm
by BRUMBEAR
Thats a little vague I really can't get an idea where to start with that. Battery dies what do you mean a total loss of power? Or does the engine just stall?
Posted: Wed Oct 16, 2013 1:53 am
by gosthrider82
I mean your doing 55 mph with plenty of power and lose half or more power. so you could go wide open with no change but you do slow down. after you can only drive for around half a mile. if you continue to ride with it acting up the engine will die and the battery is dead. but if you stop shut the engine off (turn the key off) then wait 1 sec (turn the key on) start the engine the bike run's fine like nothing ever happened. so far it only does it when your riding on open road. it doesn't drop a jug in town red light to red light so there is no over heating. the battery is only 2 weeks old
Posted: Wed Oct 16, 2013 5:58 am
by Johnj
I'd start by checking the charging circuit.
Posted: Wed Oct 16, 2013 3:02 pm
by pchast
Plugged or restricted fuel/filter?
Posted: Thu Oct 17, 2013 10:55 am
by BRUMBEAR
Sounds like you have a short in the stator or reg that is tripping what sounds like a breaker and when it cools down it will close again. Make sure there are fuses not breakers in the system. I have seen folks put breakers in where fuses should be because of an intermittent problem like a headlight shorting a harness when it gets to hot and other issues. But other than that I would make sure your grounds are good and terminals are tight.
Posted: Fri Oct 18, 2013 9:59 am
by gosthrider82
we think we have found the problem. the coil for the rear jug 1 of the plug wires was not all the way in and we think because of that it arking in the coil,the coil has gone bad. going to order a new coil and wires and see if that really does fix it. thanks for every ones info and will let you know if that fix's it
Posted: Sat Oct 26, 2013 4:38 am
by gosthrider82
the problem end up being the fuel filter. changed that and the bike runs just fine. thanks for every ones info
Posted: Sat Oct 26, 2013 8:59 am
by BRUMBEAR
Glad ya got it sorted
