2014 EBR 1190RX - Coolness Factor = 82.9%
Posted: Fri Oct 18, 2013 4:45 am
2014 EBR 1190RX on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... 1190RX.htm
2014 EBR 1190RX on Totalmotorcycle.com
EBR Motorcycles are unlike anything else on the road or track. What makes them so different is what makes them so distinctly better.
Introducing the 2014
More than three decades of racing, engineering, and manufacturing experience goes into every motorcycle we make. You won’t be disappointed upon setting eyes on our newest creation: The 2014 EBR 1190RX. It has been built from start-to-finish with pride, joy and a relentless passion to bring you another world-class sport bike from the heart of America.
2014 EBR 1190RX Totalmotorcycle.com Features and Benefits
The new, street-legal high performance motorcycle carries EBR’s model designation 1190RX and is a direct descendant of EBR’s race-bred limited edition 1190RS Super Bike. While the 1190RX shares its sibling’s 1190cc engine and many of EBR’s exclusive performance and handling-enhancing features, it is a new design created to tame the wildest roads and rouse the most demanding riders.
“This is the culmination of decades of dedication, innovation and teamwork,” said EBR founder Erik Buell. “We have been working to create a pure rider’s machine and a true world brand.
From the heartland and the heart of America, these are extraordinary motorcycles that discerning riders everywhere will be passionate to own.”
2014 EBR 1190RX - Totalmotorcycle.com North America Specifications/Technical Details
US MSRP Price: $18,995 USD
Canada MSRP Price: See dealer for pricing in CDN
Engine (Totalmotorcycle.com)
Type ET-V2: 72° V-Twin, Liquid Cooled, Four-stroke
Bore x Stroke 4.17 in. x 2.66in. (106 x 67.5 mm)
Displacement 72.6 cu in. (1190cc)
Compression Ratio 13.4 : 1
Fuel Delivery Electronic Fuel injection with 2 port injectors and 2 showerhead injectors
Exhaust Primary + Secondary
Peak Torque 101.6 ft-lbs. @ 8200 rpm (137.8 Nm @ 8200 rpm)
Peak Horsepower 185 hp @ 10,600 rpm
Drivetrain
Primary Drive Gear Drive 36/65
Final Drive 520 Z-ring chain, 16/41
Clutch Hydraulic actuation, vacuum operated slipper
Transmission Ratios:
1st 2.46
2nd 1.75
3rd 1.38
4th 1.17
5th 1.04
6th 0.96
Dimensions (Totalmotorcycle.com)
Overall Length 80.3in. (2040mm.)
Overall Width 29.0in. (737mm)
Overall Height 43.7in. (1110mm)
Seat Height 32.5in. (826mm)
Ground Clearance 4.7in. (120mm)
Rake 22.4°
Trail 3.80in. (96.5mm)
Lean Angle 55°
Front Tire Pirelli Diablo Rosso Corsa 120/70 ZR-17
Rear Tire Pirelli Diablo Rosso Corsa 190/55 ZR-17
Fuel Capacity 4.5 gal (17.lL)
Weight (Wet, no fuel) 419lbs. (190kg)
Load Capacity 375lbs. (170kg)
Chassis (Totalmotorcycle.com)
Frame Aluminum frame with integral fuel reservoir
Swingarm Optimized stiffness aluminum
Front Suspension Showa, inverted big piston front forks
Rear Suspension Showa, single shock without linkage
Front Wheel 17 x 3.5 Aluminum
Rear Wheel 17 x 6.0 Aluminum
Front Brake 386mm (15.19in.) Single perimeter rotor, 8 piston inside-out caliper
Rear Brake 220mm (8.66in.) Disc, 2-piston Hayes Performance Brakes Caliper
Drivetrain
1st 2.46
2nd 1.75
3rd 1.38
4th 1.17
5th 1.04
6th 0.96
Rake 22.4°
Lean Angle 55°
