2013 Kymco Xciting 500Ri ABS - Coolness Factor = 39.4%
Posted: Fri Jan 24, 2014 7:42 am
2013 Kymco Xciting 500Ri ABS on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... Ri-ABS.htm
The newly designed Xciting 500 Ri ABS is powered by a 38 hp engine and rich on amenities, including underseat storage large enough for a backpack or helmet and jacket, a lockable glove box, useful 12v accessory outlet, and all of the gauges you would expect from a modern two-wheeler capable of intercontinental travel. As the model name suggests, braking assistance is provided by a new generation Bosch anti-lock braking system (ABS).
Luxurious, refined, and incredibly fast, the Xciting 500Ri is truly a state of the art product design from KYMCO. You'll never have to sacrifice comfort again with a fully automatic transmission, adjustable back rest, 4 position brake levers, and a smooth ride! Be sure to take a closer look for chrome finishing, red accents, texturized black satin side panels, and even a carpet-lined under seat storage compartment.
The Xciting 500 Ri ABS is available in Gray or Gold, both with red performance-accented rear suspension spring and brake calipers.
2013 Kymco Xciting 500Ri ABS - Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $6899 USD
Canada MSRP Price: $6995 CDN
Engine Type DOHC 4-Stroke w/EFI
Displacement 499cc
Bore/Stroke 92x75mm
Cooling System Liquid
Ignition Electric
Fuel System Synerject (Throttle Body)
Torque 6.7ft lbs@ 7000rpm
Gearbox Automatic CVT
Chassis Steel
Front Suspension Telescopic forks
Rear Suspension Dual shock
Front Brake Dual Disc
Rear Brake Disc
Front Wheel/Tire 150/70-15
Rear Wheel/Tire 150/70-14
Seat Height 30.7 in.
Wheelbase 61.8 in.
Fuel Capacity/MPG 3.38 gallons
Weight 473 lbs.
Available Colors Gold, Gray
Features Speedometer, Tachometer, Odometer, Trip Meter, Clock, Fuel & Temp, 12 Volt Accessory Outlet and a 2 Year Factory Warranty. Totalmotorcycle.com
Displacement 499cc
Bore/Stroke 92x75mm
Ignition Electric
Chassis Steel
Rear Brake Disc
Wheelbase 61.8 in.
Weight 473 lbs.
