about to burn it down...
Posted: Wed Apr 16, 2014 11:22 am
1975 GL1000, 38K miles, stock. bought the bike and it revved up slowly. took carbs apart and found that pilot rubber plugs were bad (replaced) and did a clean on the carbs. put it back together and ballast resistor went bad (replaced, installed new points, condenser, and timed.) put it all back together and got it to run pretty good using a reservoir bottle because tank was nasty. had idle trouble (pilot screws weren't set right) but revved up quick and sounded good. cleaned tank, put in line filter on and started. it ran like complete crap and the carbs flooded (never happened before.) so I took carbs back off, cleaned again (bowls had minute sediment.) hooked tank back up to carbs, ran down the road at about 70mph and it fell on it's face. wouldn't run unless on full choke w/no throttle. got back to garage and hooked up reservoir bottle and it still ran like junk. now it will only fire once then die over and over. will not stay running.
am I over thinking this and it just be a simple fuel line occlusion causing carbs to run lean? I am at the frustration point because all I did was try to get it to run better and I am on a downward spiral. any help is GREATLY appreciated
