HELP - buying advice 1985 Yamaha Maxim 700
Posted: Fri May 30, 2014 12:28 pm
by wcervant
Found a great looking 85 maxim 700 on craigslist. Bike had been sitting for 3 years. Owner says it ran great before sitting. One carb leaks gas if left, but does not leak when running. Needs fresh gas/carb cleaning. Says it idles real low and the choke is tempermental.
- Currently starts and rides.
- 36k miles
- valves adjusted at 32k
- oil changed at 35k
- selling for $895
- needs money and no longer rides bc of old age
IS THIS A GOOD RELATIVELY SAFE BUY or A HEADACHE in terms of repair?
Re: HELP - buying advice 1985 Yamaha Maxim 700
Posted: Mon Jun 02, 2014 3:42 am
by Johnj
Hello wcervent and welcome to the forum. Is everything there? All the body pieces. The airbox. Get a hold of a service manual and find out what service work is due at 36k. If the bike sat around for three years the tires are shot and need to be replaced. What kind of exhaust dos it have on it? Good Luck.
Posted: Tue Jun 03, 2014 4:19 am
by wcervant
Everything is there. Everything is stock. A little bit of a fixer upper is what I was after, but not too much of a fixer upper.
Posted: Tue Jun 03, 2014 1:53 pm
by BRUMBEAR
John is right about tires and you will probably have to add a battery,and fork seals if it's been sitting that long as well as the possibility of clutch plates doubtful but a possibility. So add that and the carb repair price to the $895 and your not terrible but it isn't a slam dunk either get the bike for a nickel and you have done well IMO
Posted: Wed Jun 04, 2014 1:47 am
by Hanson
If you can get the bike and get in safe riding condition, you still need a good helmet, boots, gloves, jacket and pants. It adds up, but then riding is such a fun activity. If you can figure out how to make it work financially, you are going to have a great time. Even if you get a bad deal, I doubt that you will regret you decision, at least not for the money issue.
Welcome to the Total Motorcycle Forum.
Safe Travels,
Richard
Posted: Sun Aug 03, 2014 3:41 pm
by vinzsalvador
wcervant wrote:Found a great looking 85 maxim 700 on craigslist. Bike had been sitting for 3 years. Owner says it ran great before sitting. One carb leaks gas if left, but does not leak when running. Needs fresh gas/carb cleaning. Says it idles real low and the choke is tempermental.
- 36k miles
- selling for $895
Go for it dude. It worth the money. :) :kicking: :kicking:
