hyosung gt250p fuel level gauge problem
Posted: Thu Jul 17, 2014 8:20 am
by Ling_Ling
Not showing correct fuel tank level. when fuel tank is empty it shows half full. even with disconnected sending unit - still half. is there any solution for this problem?
Re: hyosung gt250p fuel level gauge problem
Posted: Sun Jul 27, 2014 8:50 am
by BRUMBEAR
new stuff :D
Posted: Sun Jul 27, 2014 3:00 pm
by pchast
Victor,
First...
I've never had a Motorcycle that read correctly,
but the meter should move.
Can you take it back to the dealer?????
Do you have a voltmeter?
Do you have a maintenance manual for the bike?
Trace the wiring from the tank to the gauge.
Inspect it for shorts or grounds.
Check all the connections and clean them.
Then use the millage per tank to fill it
before it is empty.
Thats what I do...
