2015 Indian Scout - Coolness Factor = 85.4%
Posted: Fri Aug 08, 2014 5:01 am
2015 Indian Scout on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... -Scout.htm
2015 Indian Scout
The new king of the road...
The Legend is Back. Like its iconic forerunner, the all-new Indian® Scout ™ is an innovative and aesthetically stunning American cruiser. It introduces the first-ever liquid-cooled Indian Motorcycle engine – an efficient and reliable 69 cubic inch V-twin – for impressive power on demand. This new model carries the legendary Indian® Scout™ name into the future in authentic Indian® Motorcycle® style.
Indian Motorcycle proudly introduces the new Indian Scout. The 2015 Indian Scout is a contemporary interpretation of one of motorcycling’s most famous and coveted bikes. With a DNA that is long on history, the all-new Indian Scout will appeal to riders with years of experience or new to the exciting world of motorcycling. The Indian Scout delivers on the legendary brands names promise of balance, quality and style, and featuring a starting US MSRP of $10,999 is more accessible than ever.
This is the first truly new Indian Scout in more than 70 years and marks the return of the legendary bikes that conquered the infamous “Wall of Death” and carried the legendary “Indian Wrecking Crew” motorcycle race team to multiple victories. Technology and designs derived from Scout models played a significant role for Allied Forces in World War II and a 1920 Indian Scout earned the title of the “World’s Fastest Indian” as proven by Burt Munro in 1967.
Three decades of innovations, racing wins, world records and industry firsts, built the legend of the Scout and drew thousands of riders in. Indian Motorcycle designers and engineers have taken that tradition and the characteristics of the models heritage and accelerated them through modern design and technology into the new 2015 Indian Scout. A motorcycle that reflects its legendary past and accelerates Indian Motorcycle towards a bright and global future.
2015 Indian Scout - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: Thunder Black $10,999; Indian Motorcycle Red $11,299; Silver Smoke $11,299; Thunder Black Smoke $11,299 USD
Canada MSRP Price: Thunder Black $12,199; (Indian Motorcycle Red; Silver Smoke; Thunder Black Smoke: See dealer for pricing) CDN
ENGINE
Engine Type Liquid Cooled V-Twin (60 degrees)
DOHC, 4-Valves Per Cylinder, Semi-Dry Sump
Horsepower 100 hp at 8100 rpm
Peak Torque 72.2 ft-lbs at 5900 rpm
Transmission 6-speed/sliding-mesh/foot shift
Battery 12 volts / 12 amp/hour, 210 CCA, http://www.Totalmotorcycle.com, Maintenance Free AGM
Bore x Stroke 3.898” x 2.898” (99mm x 73.6mm)
Charging System 35 amp max output
Clutch Wet, multi-plate
Compression Ratio 10.7:1
Cooling System Liquid
Displacement 69 cu in / 1133 cc
Exhaust Split dual exhaust with crossover
Exhaust Control Two O2 sensors, one each bank, single three-way catalyst
in each muffler
Final Drive Belt drive, 141 tooth
Fuel & Capacity 91 octane recommended, 3.3 gal/ 12.5 ltr
Fuel System Electronic fuel injection, closed loop/60 mm bore
Oil & Capacity SAE 15W60 , 5.0 qts / 4.73 ltr
Primary Drive Gear drive wet clutch
SUSPENSION
Front Suspension Telescopic fork, http://www.Totalmotorcycle.com, 41 mm diameter, 4.7 in / 120 mm travel
Rear Suspension Dual shocks, 3 in / 76 mm travel
BRAKES
Front Braking System Single 298 mm rotor with 2-piston caliper
Rear Braking System Single 298 mm rotor with 1-piston caliper
CHASSIS
Dry Weight 538 lbs / 244 kg
Wet Weight 558 lbs / 253 kg
Ground Clearance 5.3 in / 135 mm
GVWR 988 lbs / 449 kg
Length 91 in / 2311 mm
Width 34.6 in/ 880 mm
Height 47.5 in/ 1207 mm
Rake/Trail 29° / 4.7 in / 119.9 mm
Seat Height (Laden) 26.5 in / 673 mm (25.3 in /643 mm)
Wheelbase 61.5 in / 1562 mm
Electric Lights and Gauges
GEAR RATIO (OVERALL)
1st 10.782:1
2nd 7.328:1
3rd 5.841:1
4th 4.957:1
5th 4.380:1
6th 4.034:1
Final Drive 2.357:1
WHEELS & TIRES
Front Tire 130/90-16 72H
Front Wheel Cast 16” x 3.5”
Rear Tire 150/80-16 71H
Rear Wheel Cast 16” x 3.5”
2015 Indian Scout
ENGINE
in each muffler
SUSPENSION
BRAKES
CHASSIS
1st 10.782:1
2nd 7.328:1
3rd 5.841:1
4th 4.957:1
5th 4.380:1
6th 4.034:1
Final Drive 2.357:1
WHEELS & TIRES
