2015 Kawasaki Ninja ZX-14R ABS 30th - Coolness Factor = 71.3
Posted: Fri Aug 15, 2014 8:32 am
2015 Kawasaki Ninja ZX-14R ABS 30th Anniversary / LE on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... ary-LE.htm
Prepare to experience performance in a way that only a Kawasaki can deliver. The ZX-14 is the ultimate blend of extreme excitement and everyday versitility. Feel at home traversing the mountain roads, or feel the ultimate rush hurtling down the dragstrip...
Kawasaki celebrates the 30th anniversary of the Ninja with a very limited edition of numbered 2015 ZX-14R ABS motorcycles
Only 300 ZX-14R Limited Edition motorcycles will be available, all individually numbered and finished in exactly the same shade of Firecracker Red and Metallic Graystone paint as the 1984 Ninja® 900 – the motorcycle that started the superbike revolution. It even has the same narrow Gold pinstriping and gets gold brake calipers. 30th Anniversary logos on the fairing sides and a numbered badge on the gas tank will further identify the Limited Edition models.
NEW 2015 KAWASAKI NINJA ZX-14R LIMITED EDITION FEATURES
•Limited to 300 numbered models
•Unique numbered badge on gas tank
•Finished in Firecracker Red / Metallic Graystone paint with Gold pinstriping and brake calipers
•Available to order at a Kawasaki dealer from July 15, 2014, 9:00am PDT
•Powerful 1441cc inline four-cylinder engine with selectable Power Modes
•ABS, Traction Control and adjustable suspension
•Kawasaki One-Year Warranty
Kawasaki recently released Anniversary Editions of the Ninja ZX-10R and ZX-6R featuring color schemes to celebrate the company’s success in the 2013 World Superbike Championship. Now the flagship ZX-14R commemorates the original spirit of the 1984 Ninja 900, which was the first fully faired superbike and sported Kawasaki’s most powerful engine of its day. Similarly, the 2015
ZX-14R continues that cutting edge tradition by featuring one of the most powerful production engines in the world and can claim to be the quickest production motorcycle in the world.
LIMITED EDITION
Following the official announcement of the 2015 Ninja ZX-14R ABS Limited Edition at the Laguna Seca round of the 2014 World Superbike Championship, potential customers can order one of the 300 models.
2015 Kawasaki Ninja ZX-14R ABS 30th Anniversary / LE Totalmotorcycle.com Key Features
Key Features
o One-of-a-kind 1,441cc inline-four engine is the most powerful motorcycle engine Kawasaki has ever produced, delivering the most power of any current production sportbike
o ABS brake model helps increase rider confidence and helps provide additional security in slippery situations
o KTRC traction control system addresses varying riding conditions via three different modes controlled by a switch on the left handlebar
o Back-torque-limiting slipper clutch assembly helps control chassis upset from rear-wheel torque effects while braking and downshifting
o High performance exhaust system features large-diameter tapered head pipes, a catalyzer and an efficient muffler assembly for low noise and emissions
o Aluminum monocoque frame is narrow, strong and rigid for impressive sport riding performance that complements the engine's power
o Aluminum swingarm assembly is longer than traditional designs and incorporates strengthening gussets to withstand the engine's substantial torque
o Supersport bodywork embraces the visual cues of Kawasaki siblings, includes a rear seat cowl and adds better air management for improved rider and passenger comfort
o Ten-spoke wheels reduce unsprung weight for better handling and maneuverability
o Radial-mount calipers feature individual pads for each piston, improving heat management
o Balanced, adjustable suspension settings front and rear for a comfortable ride without sacrificing performance
o Flagship finish quality with hidden bodywork fasteners
2015 Kawasaki Ninja ZX-14R ABS 30th Anniversary / LE - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $15,899 USD
Canada MSRP Price: $18,199 CDN
Engine: Four-stroke, liquid-cooled, DOHC, four-valve per cylinder, inline-four
Displacement: 1,441cc
Bore x stroke: 84 x 65mm
Compression ratio: 12.3:1
Fuel injection: DFI® with four 44mm Mikuni throttle bodies
Ignition: TCBI with Digital Advance
Transmission: Six-speed
Final drive: Sealed chain
Rake / trail: 23-deg / 3.7"
Front tire: 120/70 ZR17
Rear tire: 190/50 ZR17
Wheelbase: 58.3"
Front suspension / wheel travel: 43mm inverted cartridge fork with adjustable preload,
18-way compression and 15-way rebound damping adjustment / 4.6"
Rear suspension / wheel travel: Bottom-link Uni-Trak® and gas-charged shock with adjustable preload, stepless rebound and compression damping adjustments, adjustable ride height / 4.9"
Front brakes: Dual semi-floating 310 mm petal discs with dual radial-mounted four-piston calipers in gold, ABS
Rear brakes: Single 250mm petal disc with twin-piston caliper in gold, ABS
Overall length: 85.4"
Overall width: 30.3"
Overall height: 46.1"
Ground clearance: 4.9"
Seat height: 31.5"
Curb weight: 590.9 lb
Fuel capacity: 5.8 gallons
Color: Firecracker Red / Metallic Graystone / Gold pinstriping
LIMITED EDITION
Key Features
Wheelbase: 58.3"
Seat height: 31.5"
