Honda Shadow 1100t gas leak
I have a weird issue. When I crank the bike, I notice gas coming from the bottom of the right exhaust pipe. Looking at the bottom of the pipe, I notice a small perfectly round hole where the gas appears to be coming from. there are other area that appear to be the same size, but they are welded over. Is it normal for some gas to come into the exhaust pipe, and should that hole be covered or left open. thks for the help
- dr_bar
- Real Name: Doug
- Years Riding: 44
Re: Honda Shadow 1100t gas leak
Is it gas or just condensation in the exhaust, that's what the hole is for...
smells like gas, comes out as vapor though
- Tricycle Squid
- Real Name: Carter
- Years Riding: 0
- My Motorcycle: suplendor
honda 750 shadow gas leak at the top forward of the two carbs, there is a hose linked together with a ''T'', from - Honda 2005 VT 1100 C Shadow Spirit.
DGCustomerFirst
DGCustomerFirst
- Tricycle Squid
- Real Name: Crystal Smith
- My Motorcycle: 2012
I think, The small round hole you described could be a result of corrosion, damage, or a manufacturing defect. It is recommended to have the hole inspected and repaired by a qualified motorcycle mechanic or technician. I hope this may be help you to solve this issue.
- Tricycle Squid
- My Motorcycle: moto
I think you should take your bike to the dealer.Cooper895 wrote: Mon Sep 06, 2021 8:15 pm honda 750 shadow gas leak at the top forward of the two carbs, there is a hose linked together with a ''T'', from - Honda 2005 VT 1100 C Shadow Spirit.
