07 hyosung 250 gt chain issue
Posted: Mon Sep 01, 2014 8:54 am
by dygertj
So my bike is having issues with keeping the chain on it likes to pop off once I hit 2nd gear it started a month ago with the chain had a lot of extra play so I put it back on and slide the rear tire back to tighten the chain ran great then last night on way home form riding on a long road trip I had to go down a gravel road and the chain piped off again. The tension. On the chain looks good but it pops off in 2nd gear now
Re: 07 hyosung 250 gt chain issue
Posted: Tue Sep 02, 2014 9:59 am
by GS_in_CO
if you slid the wheel back and got it cocked a little bit the mis-aligned sprocket would tend to want to throw the chain.
Check rear wheel alignment very carefully.
Also don't trust the marks on the swingarm completely. Sometimes they aren't right.
Posted: Tue Sep 02, 2014 12:48 pm
by BRUMBEAR
+1, its probably nothing to do with the gear but accrued speed that's throwing your chain they must be equal.
Posted: Wed Sep 03, 2014 1:57 am
by GS_in_CO
BRUMBEAR wrote:+1, its probably nothing to do with the gear but accrued speed that's throwing your chain they must be equal.
Can you say that in English please?
Posted: Wed Sep 03, 2014 11:26 am
by BRUMBEAR
Sorry I agree the op stated 2nd gear his chain popped off I meant IMO you are correct the axle is not even. I also meant second gear really had nothing to do with the problem if the op was worried it was a trans issue. The speed of the wheel with an uneven adjustment is most probably the cause as you stated not the gear he was in.
Posted: Thu Sep 04, 2014 3:46 am
by GS_in_CO
Your response sort of looked like govt/accountantese which requires some sort of translator for normal people.
Bottom line- chain throwing is not a gear issue. It's either chain slack/wear or sprocket misalignment. The speed just moves the slack around.
