2014 Suzuki Burgman 650 ABS - Coolness Factor = 35.2%
Posted: Fri Sep 19, 2014 4:55 am
2014 Suzuki Burgman 650 ABS on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... 650ABS.htm
Exhilarating...
For generations of riders, the Burgman has redefined the two-wheel luxury scooter experience. It brought performance and comfort into a market once unimaginable. For 2014, the Burgman 650 ABS continues to improve with new styling matched with unbeatable performance.
Notable changes to the Burgman 650 ABS include refinements in the transmission setting and a reduction of mechanical losses contribute to a boost in fuel economy by 15%* compared to the previous model in Drive Mode. Drive Mode heightens efficiency at normal road speeds and gives smooth, linear, almost shock-free power delivery for easy riding. Power Mode gives more punch when you twist the throttle. And Manual Mode lets you thumb-toggle between six preset gear ratios for a unique feeling of control. The SECVT’s updated design includes new clutch plates that cause 35% less drag.
You can feel the nimbleness and abundance of power in your hand. It is simply exhilarating! With refinements in the transmission setting that easily allows you to downshift, accelerate, and maneuver around traffic and through every road, there’s no better time than to hop on the Burgman 650 ABS than today!
2014 Suzuki Burgman 650 ABS - Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $10999 USD
Canadian MSRP Price: $11,099 CDN (known as the 2014 Suzuki Burgman 650 Executive ABS in Canada)
Engine:
Engine 638cc, 4-stroke, liquid-cooled, 2-cylinder, DOHC
Bore x Stroke 75.5mm x 71.3mm (2.97 in x 2.81 in)
Compression Ratio 11.2 : 1
Fuel System Suzuki Fuel Injection
Starter Electric
Lubrication Wet sump
Drive Train:
Transmission Automatic - SECVT
Final Drive Gear Drive
Chassis:
Suspension Front Telescopic, coil spring, oil damped
Suspension Rear Swingarm type, coil spring, oil damped
Brakes Front Disc brake, twin
Brakes Rear Disc brake
Tires Front 120/70R15M/C 56H, tubeless
Tires Rear 160/60R14M/C 65H, tubeless
Fuel Tank Capacity 4.0 US
Color Metallic Mat Fibroin Gray
Electrical:
Ignition Electronic ignition (Transistorized)
Dimensions and Curb Weight:
Overall Length 2265 mm (89.2 in)
Overall Width 810 mm (31.9 in)
Wheelbase 1585 mm (62.4 in)
Ground Clearance 125 mm (4.9 in)
Seat Height 755 mm (29.7 in)
Curb Weight 278 kg (613 lbs)
Exhilarating...
Engine:
Starter Electric
Drive Train:
Chassis:
Electrical:
