2014 Norton Commando 961SF - Coolness Factor = 81.2%
Posted: Fri Dec 19, 2014 6:59 am
2014 Norton Commando 961SF on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... -961SF.htm
An all new Norton 961cc parallel twin with hydraulic push-rod valve actuation, dry sump, 3 bearing crank, balancer shaft and cassette gear box. Built and developed in house at the Norton UK Factory.
2014 Norton Commando 961SF - Totalmotorcycle.com International Specifications/Technical Details
US MSRP Price: $ See dealer for pricing in USD
Canada MSRP Price: Single Seat $23,900; Dual seat $24,850 CDN
UK/European MSRP Price: £16,495 GBP (Out The Door, Price includes VAT at 20%).
Power Assembly
Engine type
Displacement
961cc
Cooling System
Air/Oil
Valve actuation
Push rod, 2 valves per cylinder
Bore x stroke
88mm x 79mm
Compression ratio
10.1:1
Power
80PS @ 7700RPM
Torque
80Nm @ 6000RPM
Exhaust
Black chrome front pipes and reverse cone silencers
Ignition
Crank fired electronic
Euro 3 compliant with electronic fuel injection and multiple 3 way catalytic converter
Transmission
Gear box
Constant mesh 5 speed
Final drive
525 “O” ring chain
Clutch
Wet multi-plate hydraulic lifter
Electric Start
Electronics & Controls
Instrumentation
Norton electronic analogue speedo & tachometer
Digital information Display
Charging System
300 watt hi-output
Frame
Frame
Steel tubular with integral oil tank
Front suspension
Ohlins USD
Rear Suspension
Ohlins
Swing arm
Twin-sided steel construction
Wheelbase
1420mm (55.9 in)
Rake
24.5 degrees
Trail:
99mm (3.9 in)
Front wheel
36 spoke 3.50 x 17" Alloy Rim (Black)
Rear wheel
40 spoke 5.5 x 17" Alloy Rim (Black)
Front tyre
120/70 x 17"
Rear tyre
180/55 x 17"
Front wheel travel
115mm (4.53 in)
Rear wheel travel
100mm (3.94 in)
Handlebars
Alloy tapered bar in black
Miscellaneous
Carbon flyscreen
Carbon chain guard
Carbon front and rear mudguards
Fuel tank capacity
17 litres (3.82 UK gallon)
Dry weight
188kg (414.5 lbs)
Seat height
813mm (32 in)
Steering
Fully machined billet yokes
Brakes
Front brakes •Twin Brembo 320mm fully-floating high carbon stainless steel discs
• Brembo 4 piston 'goldline' radially mounted calipers
•Stainless steel braided hoses
Rear brakes •Single Brembo 220mm disc
• Brembo 2 piston caliper
•Brembo rear brake master cylinder
Performance
Power
80PS @ 7700RPM
Torque
80Nm @ 6000RPM
Power Assembly
Engine type
Displacement
961cc
Cooling System
Air/Oil
Valve actuation
Bore x stroke
88mm x 79mm
Compression ratio
10.1:1
Power
80PS @ 7700RPM
Torque
80Nm @ 6000RPM
Exhaust
Ignition
Transmission
Gear box
Final drive
525 “O” ring chain
Clutch
Electric Start
Instrumentation
Charging System
300 watt hi-output
Frame
Frame
Front suspension
Ohlins USD
Rear Suspension
Ohlins
Swing arm
Wheelbase
1420mm (55.9 in)
Rake
24.5 degrees
Trail:
99mm (3.9 in)
Front wheel
Rear wheel
Front tyre
120/70 x 17"
Rear tyre
180/55 x 17"
Front wheel travel
115mm (4.53 in)
Rear wheel travel
100mm (3.94 in)
Handlebars
Miscellaneous
Carbon flyscreen
Carbon chain guard
Fuel tank capacity
Dry weight
188kg (414.5 lbs)
Seat height
813mm (32 in)
Steering
Brakes
Performance
Power
80PS @ 7700RPM
Torque
80Nm @ 6000RPM
