2015 BMW K1300S - Coolness Factor = 78.3%
Posted: Fri Mar 27, 2015 5:18 am
2015 BMW K1300S on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... K1300S.htm
BMW K1300S on http://www.Totalmotorcycle.com
The interceptor. The athlete. Aerodynamic, avant-garde...
Do you know of another sporty bike with this profile? A bike that develops such pulling power with 175 hp that it take the heat out of many a 200 hp bike? But a bike you can still take out on a quick trip simply because it has great everyday suitability? At the same time a technological treat?
The BMW K 1300 S: supreme power with the sportiest of understatement. Why not try it out right away!
The BMW K 1300 S Motosport
An athlete in top form.
Even in the standard version, the BMW K 1300 S leaves nothing to be desired when it comes to performance. Can it be taken any further? It certainly can: even at first glance the K 1300 SS "Motorsport" special model looks like an athlete raring to go. In the paint finish Black Storm metallic and Light White non-metallic with the accentuation colour Lupin Blue metallic it instantly conveys the character of a power bike. The overall look is rounded off with a tinted windshield.
And the "Motorsport" special model has a whole lot to offer in terms of detail, too: the HP footrest system gives the rider individual setting options and is extra narrow for greater banking freedom. The hand-made Akrapovic silencer made of titanium produces a powerful sound as well as offering clear benefits in terms of weight. Its sporty light alloy forged wheels make the K 1300 S Motorsport even more agile.
2015 BMW K1300S - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $15,855 (including ABS) USD
Canada MSRP Price: $18300 CDN
Engine
Type Water-cooled 4-stroke in-line four-cylinder-engine, four valves per cylinder, two overhead camshafts, dry sump lubrication
Bore x stroke 80 mm x 64,3 mm
Capacity 1.293 ccm
Rated output 175 hp (129 KW) at 9,250 rpm
Max. torque 103 ft-lb (140 Nm) at 8,250 rpm
Compression ratio 13.0 : 1
Mixture control / engine management Electronic intake pipe injection/digital engine management including knock sensor (BMS-K)
Emission control Closed-loop 3-way catalytic converter, http://www.Totalmotorcycle.com, emission standard EU-3
Performance / fuel consumption
Maximum speed Over 125 mph
Fuel consumption per 100 km at constant 90 km/h 50 mpg, at a constant 55 mph
Fuel consumption per 100 km at constant 120 km/h
Fuel type Unleaded premium only.
Electrical system
Alternator three-phase alternator 580 W
Battery 12 V / 12 Ah, maintenance-free
Power transmission
Clutch Multiple-disc clutch in oil bath, hydraulically operated
Gearbox Constant mesh 6-speed gearbox
Drive Shaft drive
Chassis / brakes
Frame Bridge-type frame, cast aluminum, load-bearing engine
Front wheel location / suspension BMW Motorrad Duolever; central spring strut
Rear wheel location / suspension Cast aluminum single-sided swing arm with BMW Motorrad Paralever; central spring strut with lever system, http://www.Totalmotorcycle.com, spring pre-load adjustable hydraulically (continuously variable) at handwheel, adjustable rebound damping
Suspension travel front / rear 4.5/5.3 inches (115 mm/135 mm)
Wheelbase 62.4 inches (1,585 mm)
Castor 4.1 inches (104.4 mm)
Steering head angle 60,4°
Wheels Cast aluminum
Rim, front 3,50 x 17"
Rim, rear 6,00 x 17"
Tyres, front 120/70 ZR 17
Tyres, rear 190/55 ZR 17
Brake, front Twin disc, floating brake discs, diameter 320 mm, 4-piston fixed calipers
Brake, rear Single disc brake, diameter 265 mm, double-piston floating caliper
ABS STANDARD (part integral, can be switched off)
Dimensions / weights
Length 85.9 inches (2,182 mm)
Width (incl. mirrors) 35.6 inches (905 mm)
Height (excl. mirrors) 48 inches (1,221 mm)
Seat height, unladen weight 32.3 inches Standard; optional seat height 31.1 inches (available as accessory and/or factory option, see an authorized BMW Motorrad dealer)
Inner leg curve, unladen weight 71.3 inches Standard; optional inner leg curve (inseam) 68.9 inches (seat available as accessories and/or factory option, see an authorized BMW Motorrad dealer)
Unladen weight, road ready, fully fuelled 1) 560 lbs (254 kg)
Dry weight 2) 503 lbs (228 kg)
Permitted total weight 1,014 lbs (460 kg)
Payload (with standard equipment) 573 lbs (206 kg)
Usable tank volume 5 gallons (19.0 liters)
Reserve Approx. 1 gallon (4.0 liters)
Engine
Capacity 1.293 ccm
Electrical system
Power transmission
Drive Shaft drive
Chassis / brakes
