2012 Bimota DB10B Motard - Coolness Factor = 63.6%
Posted: Fri Apr 10, 2015 5:44 pm
2012 Bimota DB10B Motard on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... Motard.htm
Wet your appetite for curves
A bike that is born to devour the tarmac, curve after curve up to satiate even the hungriest rider, and when the "starvation" of road is satisfied, you can continue to feed the eyes lost in the details of this Bimota, where carbon , special billet and passion combine to make every moment memorable, since the key illuminates the heart and the motor, until returned in the evening after having tamed boxes tougher roads or city traffic more challenging, always with the smile on the lips ...
2012 Bimota DB10B Motard Model Highlights
The generously sized seat offers good feelings for each type of rider and style, standing on the bike has the dominant visual imposing tank that ideally the front end, to free up the nose in plain carbon but decided that it leaves room interpretations concerning the definite character of DB10.
2012 Bimota DB10B Motard Features and Benefits
Fork 50mm in diameter, with raised excursion increased by 10mm, pure motard setup with advanced platforms, dual front disc 320mm with radial wave, Arrow exhaust and carbon abundance have the right mix to tame the powerful 100-horsepower twin-cylinder 1100 of cylinder, 13.5 liter fuel tank and raised handlebar complete the equipment of the bike's incredible that there never tire.
2012 Bimota DB10B Motard - International Specifications/Technical Details
MSRP Price: Sorry, I never received MSRP pricing.
Model Bimota Motorcycles DB10 B.MOTARD
2 valves per cylinder
2-cylinder engine, 4 stroke
Displacement 1078cc
Bore x stroke 98x71, 5 mm
Compression ratio 10,7:1
Power electronic injection
Electric Start
Power 98hp /7500 rpm
Rpm Max torque 10.5 kgm/5500 rpm
Transmission Chain
Frame made of chrome-molybdenum
Front suspension 50mm inverted front forks, 165mm travel
Rear suspension monoshock adjustable for preload high and low speed 'extension and compression
Front brake 2 x 320mm discs, Brembo radial caliper 4 pads separated
Rear brake 220mm disc, caliper Bimota
Dry weight 168 kg.
Capacity tank 13.5 liters.
Speed max 220 km / h
Front tire 120/70-17''
Rear tire 180/55-17''
Displacement 1078cc
Electric Start
Transmission Chain
Dry weight 168 kg.
