2015 Piaggio Fly 150 - Coolness Factor = 56.1%
Posted: Fri May 29, 2015 5:59 am
2015 Piaggio Fly 150 on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... ly-150.htm
2015 Piaggio Fly 150 on http://www.Totalmotorcycle.com
Classic Italian style and top comfort...
Whether you are new to two wheels, want to beat the commuter blues or simply need a more economical mode of transport, the Fly 150 is the scooter to suit your lifestyle.
Equipped with the super efficient 3-valve 150cc engine for lower emissions, maximum performance and fuel economy of 44 km/h.
With classic Italian style and top comfort, the Fly 150 features telescopic hydraulic forks and 12'' wheels with large tubeless tires for easy handling and safety on both urban and uneven roads.
The Fly inherits Piaggio’s tradition of success, using the latest technology and design trends. The result is a reliable vehicle for everyday riding that stands out for its style, comfort and ease of use. Light, compact, and agile, the Fly is easy to use, simple to park, and offers excellent power-to-weight ratio for enhanced performance. With 12” alloy wheels and front disc brakes the Fly may be the best value on the market.
2015 Piaggio Fly 150 http://www.Totalmotorcycle.com Key Features
Ideal For Short trips and running errands
• Single cylinder, four-stroke Piaggio Leader engine
• Aerodynamic and protective front shield
• 12” alloy wheels for agility and stability—far superior to steel
• Front disc brake
• Underseat storage for helmet
All 2015 and newer Piaggio scooters include:
2-year unlimited-mileage warranty. *Limits are outlined in the warranty booklet. See dealer for details.
1 free year of road side assistance provided by Road America.
2015 Piaggio Fly 150 - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $2999 USD
Canada MSRP Price: $3195 CDN
ENGINE TYPE
Single-cylinder, four-stroke Piaggio LEADER
CYLINDER CAPACITY
155 cc
BORE X STROKE
2.28" x 2.3"
MAX POWER AT SHAFT
9 kW at 7,000 rpm
MAX TORQUE
13 Nm at 6,000 rpm
MAX SPEED
61 mph
FUEL TANK CAPACITY
1.8
GAS MILEAGE
104 mpg
DISTRIBUTION
Single overhead camshaft SOHC with three valves
COOLING SYSTEM
Forced air
LUBRICATION
Wet sump
IGNITION
Electronic
GEARS
CVT automatic ratio variator ('Twist 'n go')
CLUTCH
Dry automatic centrifugal type
CHASSIS
Tube type
FRONT SUSPENSION
Telescopic hydraulic forks, 32 mm
REAR SUSPENSION
Hydraulic single shock absorber, 73 mm
FRONT BRAKE
Disc 220 mm with dual-piston floating calliper
REAR BRAKE
Drum 140 mm
FRONT TIRE
120/70, 12"
REAR TIRE
120/70, 12"
LENGTH
72.8"
WIDTH
27.7"
WHEELBASE
52.2"
SEAT HEIGHT
29.9"
DRY WEIGHT
247
TYPE APPROVAL
EPA and CARB
COLORS
Pearl White, Graphite Black
• Front disc brake
ENGINE TYPE
CYLINDER CAPACITY
155 cc
BORE X STROKE
2.28" x 2.3"
MAX POWER AT SHAFT
9 kW at 7,000 rpm
MAX TORQUE
13 Nm at 6,000 rpm
MAX SPEED
61 mph
FUEL TANK CAPACITY
1.8
GAS MILEAGE
104 mpg
DISTRIBUTION
COOLING SYSTEM
Forced air
LUBRICATION
Wet sump
IGNITION
Electronic
GEARS
CLUTCH
CHASSIS
Tube type
FRONT SUSPENSION
REAR SUSPENSION
FRONT BRAKE
REAR BRAKE
Drum 140 mm
FRONT TIRE
120/70, 12"
REAR TIRE
120/70, 12"
LENGTH
72.8"
WIDTH
27.7"
WHEELBASE
52.2"
SEAT HEIGHT
29.9"
DRY WEIGHT
247
TYPE APPROVAL
EPA and CARB
COLORS
