CLUTCH LEVER Repair ... ?
Posted: Tue Jun 23, 2015 9:56 am
by ptmxtwo
[no search results found]
i dropped my 2013 Yamaha and bent the end of the clutch lever....
It looks as if the lever is made of aluminum. If i try to bend it back, or heat it and bend it back, will it break?
What are my options, including replacement.
thank you
from a newrider
bent clutch lever
bent clutch lever
ClutchLever Bent-sm.jpg (24.77 KiB) Viewed 14306 times
Re: CLUTCH LEVER Repair ... ?
Posted: Tue Jun 23, 2015 2:55 pm
by pchast
Sometimes. And sometimes mine will bend back without breaking without
heat. I've had to buy replacements a couple of times too.
Its happened more than I like to own up to.
Posted: Wed Jun 24, 2015 4:49 am
by Johnj
Save yourself the disappointment and go buy a lever. A new lever. :lol:
Posted: Fri Apr 14, 2017 12:05 pm
by Carlos Miguel
Well, this is an old post but I recently have a similar problem with the brake lever.
I have a video showing how to make it in case someone else have the same problem.
https://youtu.be/3-xKotOrdUc
