Opinion: Don't ride with brights on.
PhilD9er
#1 Unread post by PhilD9er »
I ride daily through hectic LA, (downtown, Hollywood, westside), traffic. I flash my brights at intersections, or when someone is poised to make a turn in front of me. On several occasions I've had cars 'panic stop' when I did this.
As a driver a constant bright light did nothing for me. Not in this traffic climate. Plus, it runs down your battery.
"People who consider themselves brutally honest are usually putting the emphasis on brutality"
Paraphrase of some English guy.
c-los
#2 Unread post by c-los »
Well, I've had a few friends tell me that my low beam headlight looks really dim in daylight hours. I ride with high beam on and when I'm behind someone like at a light, I switch to low beam.
sapaul
#3 Unread post by sapaul »
I ride full brights all the time, wear bright clothes, toot my horn and generally make a nuisance of my self to get noticed.
Scott58
#4 Unread post by Scott58 »
My S50 has a "passing switch" that flashes the brights on and off. i use it alot more then I thought I would.
05 Honda Rebel
04 Spitfire Cub-24
05Suzuki S50
rapidblue
#5 Unread post by rapidblue »
My headlight switch is bunk so I'm forced to hard wire it to either high or low.
I chose High, I'd rather "pee" someone off for 2 seconds than die :)
80 honda CB750F Super Sport
stargazertony
Re: Opinion: Don't ride with brights on.
#6 Unread post by stargazertony »
PhilD9er wrote:I flash my brights at intersections, or when someone is poised to make a turn in front of me. On several occasions I've had cars 'panic stop' when I did this.
Well, here in PA and other states I've visited, flashing lights means "Go Ahead" and not the warning of "I'm coming though". When you flash your lights you are telling the oncomming driver to proceed with his/her turn.
bennettoid
#7 Unread post by bennettoid »
I ride with High Beam on. That was actually a question on the Endorsement test, I think.
'94 vulcan 750
ronboskz650sr
#8 Unread post by ronboskz650sr »
High beams for me. Our traffic isn't as heavy, but to me visibility is visibility. I leave it on and steady until dusk, then use low beams as normal night driving dictates. I, too wear bright yellow, and swerve to and fro to put my light in the most visible spot (during the day). It keeps people away from me and is more fun at the same time. And the police always smile and wave. You are yielding your right of way if you flash your lights here, except for passing.
Ride safe...God bless!
-Ron
Craig7220
#9 Unread post by Craig7220 »
If its daylight, I ride with highbeam on. I do use the lowbeam at night. With some of the cage drivers around here, I need all the help I can get in being seen.
Craig
2005 Suzuki C-50 Limited
Lawk
#10 Unread post by Lawk »
Running your high beam during the day is a great idea and it is recommended buy any MSF. Flashing you high beam does make you more visible, but sends mixed messeges to cagers.
Also, running your high beam wont drain your battery unless your engine is off. :|
Before you judge someone, walk a mile in their shoes. Then, when you do judge them you are a mile away, and you have their shoes.
