DOET RADICAL MOTARD 250cc STAFF REVIEW
Posted: Fri Nov 27, 2015 4:06 am
The DOET RADICAL MOTARD 250cc is a beast of a motorcycle. It's light weight, easy to handle, yet it has the torque you need to make it fun on the streets and safe on the freeway. It might just be in the top 5 best beginner motorcycles out there.
Fun for the streets
The DOET RADICAL MOTARD 250cc is the ultimate wolf in sheep's clothing. It's single cylinder engine comes in at a respectable 250cc's, giving you more grunt when passing at higher speeds. With a single cylinder engine you expect more torque down low, and while the DOET RADICAL MOTARD 250cc does have some, it really begins to shine in the mid range and higher.
This is one bike that you can be a bit of a hooligan on. It will pull power wheelies if you give it a good helping of throttle and drop the clutch. Not many beginner bikes can say that!
Great Learner Bike
Even though this bike encourages you to be a bit of a hooligan, it really is set up perfectly for new riders. It doesn't have excessive plastic fairings so it will be able to survive a drop much better than something fully faired. The way that the engine delivers power is also predictable and gives you practice shifting through the gears.
The bike is also lightweight, as most bikes in this class are. That REALLY helps when you are doing some low speed maneuvers and you get off balance. It's much easier trying to save a smaller bike.
Weird and bad things...
The DOET RADICAL MOTARD 250cc is a great all around bike, but there are still a few things that are far from perfect. The first is the play in the throttle. Most of these smaller RADICAL have a bit of play in the throttle before it actually starts engaging the engine. That's not a huge thing, and it could be fixed with a little bit of wrenching on the owners part. Still, it sucks having to fix something on a brand new bike, even if its not critical to riding.
The most glaring thing about this bike is the absence of hazard indicators. It has turn signals and they work great, but there is no button that I can see that lets you put on your hazard flashers. That seems odd that they would forget or even choose not to include one.
Some riders also complain about the alloy wheels being fragile if you are going off road or traveling on heavily potholed streets. This may be the case, but the alloy wheels are designed specifically for racing in order to be light weight. If you ride on decent roads and avoid taking your bike in the dirt (which it's not design for), then you will be more than fine. These wheels make it a great bike to take to the track.
Is the RADICAL MOTARD for you?
That really depends on what type of rider you are. If you are a new rider and you want a bike that is safe, reliable, inexpensive, and stylish, I think the DOET RADICAL MOTARD 250cc could fit that bill. It works especially well if you know you have a bit of a wild side and you are nervous about getting bored with a smaller bike. You won't get bored with the DOET!
If you are a rider trying to decide between a +200cc machines the Radical may also fit that role nicely. It has a bit more power than many of the 300cc bikes out there, and the fact that it is so light weight really helps that power ratio. It cruises well on the freeway and it has the power to pass people even at higher speeds.
The RADICAL wouldn't be for you if you really don't like the look of it. It's a unique looking bike and it's not as sporty or sexy. It's more utilitarian, and in my opinion, a bit more badass. It also wouldn't be the best bike if you wanted to do a lot of off road riding. It really is a street bike and it's designed for paved roads.
Fun for the streets
Great Learner Bike
