2016 Ural Dark Force - Coolness Factor = 73.2%
Posted: Fri Dec 04, 2015 7:31 am
2016 Ural Dark Force on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... -Force.htm
Join the Dark Side, we have cookies...
From a factory far, far away; nestled in the Ural Mountains, comes the Dark Force. Standard equipped with Lightsaber®, LED lighting, and fully blacked out to hide you in the shadows.
Inspired by the world of Star Wars®, we created a motorcycle that lets your inner child explore the dark side with little damage to the real world balance of power. Come to the dark side...we've got sidecars!
Limited Edition of 25 Builds
2016 Ural Dark Force http://www.Totalmotorcycle.com Key Features
Star Wars: Episode VII - The Force Awakens with new Ural Dark Force...
Thirty years after defeating the Galactic Empire, Han Solo and his allies face a new threat from the evil Kylo Ren and his army of Stormtroopers! Now ride the motorcycle Darth Vader would have owned, the new 2016 Ural Dark Force including lightsaber! Sorry Luke Skywalker, it is a limited run of 25... Star Wars 2016 Ural Dark Force
Lightsaber® equipped.
Each Dark Force comes standard with one (1) extendable 3' Lightsaber® mounted to the sidecar. Easily accessible and totally secure, ready to battle the unknown.
High-Visibility LED headlight
Black ceramic coated exhaust with black engine
Enduro bench seat with room for a 3rd passenger
2016 Ural Dark Force - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $14,999*
Canada MSRP Price: $ CDN
Engine and Transmission
•Displacement, cc: 749
•Engine type: OHV air cooled 2 cylinder 4 stroke “boxer” (flat twin)
•Valve per cylinder: 2
•Bore and stroke (mm x mm): 78 x 78
•Max output (hp): 41 @ 5500 rpm
•Max torque (ft-lbs): 42 @ 4300 rpm
•Compression: 8.6:1
•Fuel system: Throttle body EFI
•Starting: Electric & Kickstart
•Clutch Double-disc dry
•Transmission type: Manual
•Speeds: 4 forward 1 reverse
•Primary drive (rear wheel): Driveshaft
•Final drive ratio: 4.62
•Engageable sidecar wheel drive: No
Physical Measurements
•Overall length, inch.: 91.6
•Overall heights, inch.: 53.8
•Overall width, inch.: 63.6
•Seat height, (unladen), inch.: 31.0
•Ground clearance (unladen),inch.: 6.5
•Dry weight, lbs: 700
Electrical
•Alternator: Denso, Peak Output 40 Amp @ 14vdc, 560 Wt
•Battery: FAYTX20HL (12V, 20Amp/h)
•Headlight: H4
•Spark plugs: NGK BPR6HS
Chassis
•Front suspension: IMZ leading link fork
•Rear suspension: Double sided swing-arm with two Sachs hydraulic spring shock absorbers, 5x adjustable
•Sidecar suspension: Single sided swing-arm with Sachs hydraulic spring shock absorber, 5x adjustable
•Wheels: 2.5X18 Aluminum rims with steel spokes
•Tires: Heidenau, 4.0x18”
•Front brake: 4-piston fixed Brembo caliper with 295mm floating NG rotor
•Rear brake: HB big bore single piston integrated floating caliper with 256mm fixed NG rotor
•Sidecar brake: 2-piston fixed Brembo caliper with 245mm floating NG rotor
Misc.
•Fuel grade: 91 Octane, unleaded
•Fuel tank capacity, gallons: 5.0
•Reserve, gallons: app. 1
•Estimated fuel economy, mpg: 31-37
•Estimated range, miles: 155-185
•Recommended max cruising speed, mph: 70
•Max permissible weight, lbs:1325
•Trunk volume, cubic ft.: 2.9
Warranty
•2-years parts and labor unlimited mileage.
•Compression: 8.6:1
Electrical
•Headlight: H4
Chassis
Misc.
Warranty
