2016 Harley-Davidson Low Rider S - Coolness Factor = 78.2%
Posted: Fri Jan 29, 2016 6:11 am
2016 Harley-Davidson Low Rider S on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... ider-S.htm
The new Low Rider® S takes the factory custom genre to a raw and powerful new edge. Get behind the fixed speed screen and hang on...
The Low Rider S joins the Fat Boy® S and Softail Slim® S as the third model in the Harley-Davidson S Series of cruiser motorcycles, bikes designed to deliver maximum performance with styling inspired by global custom motorcycle culture. Powered by the Screamin’ Eagle® Twin Cam 110™ engine with upgraded suspension and brakes, the Low Rider S is stripped down and ready for action.
HARLEY-DAVIDSON LOW RIDER S PUSHES CRUISER PERFORMANCE TO THE EDGE
New Performance Cruiser Features Screamin' Eagle Muscle and Stripped-Down Style
MILWAUKEE (January 27, 2016) - The original Harley-Davidson® Low Rider® model pushed the limits of a factory-custom motorcycle. Now Harley-Davidson delivers a new generation of performance and blacked-out style with the mid-year launch of the Low Rider® S model.
Powered by the Screamin' Eagle® Twin Cam 110™ engine, the Low Rider S model joins the recently released Fat Boy® S and Softail Slim® S models as the third member of Harley-Davidson's S Series cruiser lineup, bikes designed to deliver maximum performance with styling inspired by global custom motorcycle culture. Upgraded suspension and brakes complete the performance package of a motorcycle that's stripped down and ready for action.
2016 Harley-Davidson Low Rider S http://www.Totalmotorcycle.com Key Features
• Screamin’ Eagle® Heavy Breather performance intake
• Fat Bob-style 2-into-2 exhaust
• 6-speed Cruise Drive transmission
• Cruise control enabled by electronic throttle control
• Premium Ride nitrogen gas-charged emulsion shocks and Premium Ride cartridge fork
• Triple disc brakes with dual floating front rotors
• Standard Anti-Lock Braking System
• New solo seat set at 26.6 inches
• Gold tank badge pays homage to the 1977 XLCR Café Racer model
2016 Harley-Davidson Low Rider S - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: Starting from $16699 USD
Canada MSRP Price: Starting from $19499 CDN
PRICING 6
Vivid Black $16,699
Security Option STD
ABS Option STD
Cruise Control Option STD
California Emissions $200
Freight $390
DIMENSIONS
Length 89.9 in.
Seat Height, Laden 7 26.6 in.
Ground Clearance 4.13 in.
Rake (steering head) (deg) 30.5
Trail 5.1 in.
Wheelbase 64.2 in.
Tires, Front Specification 100/90B19 57H
Tires, Rear Specification 160/70B17 73V
Fuel Capacity 4.7 gal.
Oil Capacity (w/filter) 3 qt.
Weight, As Shipped 646 lb.
Weight, In Running Order 674 lb.
ENGINE
Engine 1 Screamin' Eagle® Air-cooled, Twin Cam 110™
Bore 4 in.
Stroke 4.374 in.
Displacement 110 cu in
Compression Ratio 9.2:1
Fuel System 3 Electronic Sequential Port Fuel Injection (ESPFI)
DRIVETRAIN
Primary Drive Chain, 34/46 ratio
Gear Ratios (overall) 1st 9.311
Gear Ratios (overall) 2nd 6.454
Gear Ratios (overall) 3rd 4.793
Gear Ratios (overall) 4th 3.882
Gear Ratios (overall) 5th 3.307
Gear Ratios (overall) 6th 2.79
CHASSIS
Exhaust Blacked-out, Shotgun 2-1-2 collector exhaust with dual mufflers
Wheels, Front Type 9 Magnum Gold, Split 5-Spoke Cast Aluminum
Wheels, Rear Type Magnum Gold, Split 5-Spoke Cast Aluminum
Brakes, Caliper Type 4-piston fixed front, and 2-piston torque-free floating rear
PERFORMANCE
Engine Torque Testing Method EEC/95/1
Engine Torque 2 116 ft-lb
Engine Torque (rpm) 3,500
Lean Angle, Right (deg.) 29.5
Lean Angle, Left (deg.) 30.5
Fuel Economy: Combined City/Hwy 5 44 mpg
ELECTRIC
Lights (as per country regulation), Indicator Lamps 8 High beam, directional light bar, neutral, low oil pressure, engine diagnostics, turn signals, security system (standard), 6-speed, low fuel warnings, ABS
Gauges Speedo and tachometer mounted in a wrinkle black console mounted on the tank with a black trim ring
1. Recommended 91 octane or higher fuel (R+M)/2.
2. Values shown are nominal. Performance may vary by country and region.
3. Standard and optional fuel systems may vary by country.
4. See motorcycle owner's manual for complete details.
5. Estimated from fuel economy tests on a sample motorcycle from the corresponding family conducted by Harley-Davidson under ideal laboratory conditions. Not all motorcycle models undergo fuel economy testing. Fuel economy and mileage may vary among motorcycle models within a family. Your mileage may vary depending on your personal riding habits, weather conditions, trip length, vehicle condition and vehicle configuration and other conditions. Break-in mileage may vary.
6. Prices listed are the Manufacturer's Suggested Retail Prices. Options such as color are available at additional cost. Prices exclude dealer setup, taxes, title and licensing and are subject to change. Dealer prices may vary.
7. Measurement reflects 180 lb. (81.7 kg) operator weight.
8. North America security system includes immobilizer; outside North America the security system includes immobilizer and siren.
9. Standard and optional wheels may vary by country and region.
PRICING 6
Vivid Black $16,699
Security Option STD
ABS Option STD
Freight $390
DIMENSIONS
Length 89.9 in.
Trail 5.1 in.
Wheelbase 64.2 in.
ENGINE
Bore 4 in.
Stroke 4.374 in.
DRIVETRAIN
CHASSIS
PERFORMANCE
ELECTRIC
