84 Vf1000f Power Loss When Warmed Up??
Posted: Tue Aug 23, 2005 7:53 am
Hi all, I need a little help on this one before I start throwing parts at it.
The bike is a 1984 VF1000F Interceptor with 45KM. The problem just started on a 2000 km trip I just took. What is happening is after the bike has been run for a while 5-30 min and I twist the throttle I get a throaty sound and no power and just yesterday while in the garage I started it up and warmed it up for 5 min and she backfired?
The oil is up, coolants are good, chain&tires in specs, k&n filter clean & oiled, battery fuids are up, new fuel filter, and I put 3 carb cleaning products in the fuel during the trip.
I have the official honda shop manual and I went through the trouble shooting. There is spark, yet the manual says the coils when tested with a multimeter should show a reading of 2.8 Ohms. When tested I get 000's on both coils which shows a short/no resistance, yet she starts up fine. The 1100 Sabre has the same coils so if anyone can test there own VF or Sabre and relay the reading it would be great.
I also whatched the fuel filter when warming it up and the delivery through it seemed a little intermitent. There was a air bubble in the filter and as fuel was going through it it seemed to flow in spurts which could be seen by the air bubble moving a bit in about 5 second intervals. Should it be a steady flow?
Any help would be great. Thanks in advance.
John
John
