![Confused :?](./images/smilies/icon_confused.gif)
![Sad :(](./images/smilies/icon_sad.gif)
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
His bike is carbed. I suspect fuel flow issues because I had a similar situation on my 95 Triumph Thunderbird that turned out to be a collapsed filter screen inside the tank. Also had several customers with Urals who had plugged fuel filters that reported the same symptoms, so I'm just making an educated guess here.GS_in_CO wrote:Seems to me that if were fuel delivery that the mixture would be leaning out and it would run badly - at least for carbureted engines. Fuel injection with ECU control might behave well up to the limit of fuel delivery. (I don't know which is on this machine)
Theory yields to experience.Gummiente wrote:His bike is carbed. I suspect fuel flow issues because I had a similar situation on my 95 Triumph Thunderbird that turned out to be a collapsed filter screen inside the tank. Also had several customers with Urals who had plugged fuel filters that reported the same symptoms, so I'm just making an educated guess here.GS_in_CO wrote:Seems to me that if were fuel delivery that the mixture would be leaning out and it would run badly - at least for carbureted engines. Fuel injection with ECU control might behave well up to the limit of fuel delivery. (I don't know which is on this machine)
Ok, my bad. I thought EFI wasn't standard on Sportsters until 2009. Ignore all my previous recommendations, save for the air filter, and get the bike to a shop. The EFI doesn't have many user serviceable parts and a diagnostic machine is necessary to trouble shoot the system. My apologies for steering you in the wrong direction.Ddonovan wrote:Gummiente: the manual says to rinse the air filter with "warm soapy water" so I am assuming it can be done. I did see in another place that the stock air filter can be reused once. I am looking into a K&N one for next time though. 2007 is fuel injected - no carb - but that would have been my first guess if it were possible.
I looked into doing fuel filter but from all I have been able to find out it is a huge job and one that may be beyond my skills to do with security that I won't screw it up...although I have only seen info for Dynas and one Sportster where the guy said the tank had to be removed completely! Unless anyone knows better, J might have to pay the shop
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
