2017 Norton Commando 961 Sport MKII - Coolness Factor = 79.8%
Posted: Fri Sep 09, 2016 5:48 am
2017 Norton Commando 961 Sport MKII on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... t-MKII.htm
2017 Norton Commando 961 Sport MKII on http://www.Totalmotorcycle.com
Brilliant...
The commando 961 Sport is based on the original design for the Commando with conventional forks to give a smooth, more comfortable ride and better aesthetic.
2017 Norton Commando 961 Sport MKII http://www.Totalmotorcycle.com Key Features
- Conventional ohlins forks
- Gold line axial front brake calipers
- Conventional style handlebars
- Integral brake and clutch master cylinders
- Steel chain guard
2017 Norton Commando 961 Sport MKII http://www.Totalmotorcycle.com Features and Benefits
Norton heritage
Norton returns, the name synonymous with the British sport motorcycling culture, and a brand that added so many enduring names to the motorcycle lexicon - Commando, Dominator, and of course Norton Manx whose fame was gained while dominating world Gran Prix road racing for decades. When the first Norton motorcycle, the 'Engerette', rolled out of the original Birmingham England factory in 1902, it was the birth of a lineage of motorcycles that shapes the motorcycle scene to this day. It is fitting that the new factory and world headquarters of Norton are based at the spiritual centre of British motorsport, the famous Donington Park Grand Prix Circuit, so near the traditional heart of the British motorcycle industry in Birmingham. We embrace the passion and pride of Norton's heritage, with our eyes firmly fixed on the future. We proudly continue the legacy and assume the mission of designing, engineering and building motorcycles that reflect the best of this iconic brand.
Features common to all Norton Commando 961 models
Norton is, and always will be a premium priced motorcycle with an emphasis on the quality of materials and attention to detail - designed and engineered for superior road manners and exceptional road holding. We are proudly British. More than 80% of a Norton's individual parts are 'Made in England', and combine with some of the best components available.
Chassis and running gear
The Norton reputation for superior road-holding is legendary, and continues by building a chassis of the finest materials with real world geometry and settings. Norton frames are crafted in-house at our Castle Donington factory from cold drawn 1 inch diameter, .08" wall thickness European steel. The frame also acts as the oil reservoir for the dry sump engine. Road manners are further enhanced by employing confidence inspiring and fully adjustable Ohlins suspension both front and rear, while braking tasks are handled by premier Brembo calipers, discs and master cylinders.
2017 Norton Commando 961 Sport MKII - http://www.Totalmotorcycle.com Specifications/Technical Details
MSRP Price: See dealer for pricing
Engine
Engine Type: In-house developed parallel twin with dry sump lubrication Compression ratio: 10.1:1
Displacement: 961 cc Ignition: Crank fired electronic fuel injection and multiple 2 way catalytic converters. Euro 3 compliant.
Cooling System: Air/Oil Exhaust: Stainless steel Exhaust
Valve Actuation: Push rod, hydraulic roller lifter, 2 valves per cylinder
Bore x stroke: 88mm x 79mm
Transmission
Gear box: Constant mesh 5-speed
Final drive: 525 O-ring chain
Clutch: Wet multi-plate
Dimensions
Wheelbase: 1420mm (55.9") Front tyre: 120/70 x 17"
Rake: 24.5° Rear tyre: 180/55 x 17"
Trail: 99mm (3.9") Front wheel travel: 115mm (4.53")
Front wheel: 36 spoke 3.5" x 17" Polished Aluminium Rim Rear wheel travel: 100mm (3.94")
Rear wheel: 40 spoke 5.5" x 17" Polished Aluminium Rim Seat height: 813mm (23")
Suspension
Front suspension: 43mm Ohlins RWU - adjustable preload, compression & rebound damping
Rear suspension: Ohlins twin shocks with remote reservoir - adjustable ride height, preload, rebound and compression
Brakes
Front brakes: Full Brembo system, twin Brembo 320mm fully-floating high carbon stainless steel discs & Brembo 4 piston axially mounted callipers. Brembo front brake master cylinder with integral reservoir
Rear brakes: Full Brembo system, single Brembo 220mm disc & Brembo 2 piston calliper. Brembo rear brake master cylinder
Clutch: Brembo hydraulic clutch master cylinder with integral reservoir and Brembo slave cylinder
Performance
Power: 80PS @ 6500RPM
Torque: 90Nm @ 5200RPM
Electronics & Controls
Charging system: 300 watt hi-output charging system
Instrumentation: Norton electronic analogue speedo and tachometer
Colour Options
Galactic Black with Gold Pinstripe
Titanium Grey with Black Pinstripe
Brilliant...
- Steel chain guard
Norton heritage
Engine
Transmission
Dimensions
Suspension
Brakes
Performance
Colour Options
