2004 BMW R1200C Montauk - Coolness Factor = 46.0%
Posted: Fri Oct 28, 2016 2:53 am
2004 BMW R1200C Montauk on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... ontauk.htm
For MORE information and Photos click here: http://www.totalmotorcycle.com/photos/2 ... tm#Montauk
BMW Montauk - Masters the mountains, rolls on the range.
Whether cutting through mountain gaps or rolling along open plains, the new
BMW Montauk was built for long rides through big sky country. Packed full of torque
(72 lb/ft), its got ample energy to ascend winding mountain roads and an updated
5-speed gearbox to keep the miles rolling by smoothly.
The new Montauk also features BMW’s two spark ignition system, an advancement that improves exhaust emissions, fuel consumption and response, setting a new benchmark for cruiser performance.
Stylistically, the Montauk retains the clean, elegant lines of the classic
R 1200 C but with a few extras to give it a presence all its own. Complementing the purity of the open design, the Montauk features a subtle windshield, extending riding comfort on long stretches of road.
Like its touring cousin the R 1200 CL, the Montauk takes a broader stance with a widened BMW Telelever suspension up front and vertically arranged dual headlights. The new Montauk looks equally imposing from the side. A higher, narrower passenger seat and redesigned side cover give the Montauk a powerful profile.
MANUFACTURER SPECIFICATIONS
Manufacturer - Make - Model - Year: BMW R 1200 C Montauk 2004
Motorcycle Style: Cruiser
ENGINE SPECS
Engine Type: 1170 cc, 4 Stroke - Liquid Cooled - Boxer Twin
Engine Bore and Stroke: 101 mm x 73 mm
Compression Ratio: 10:1
Valves SOHC, 4 valves/cylinder
Carburetion: Electronic intake pipe injection
Ignition System: digital engine management: Bosch Motronic MA 2.4 with overrun fuel cut-off, twin spark Ignition System:
Claimed Horsepower: 61 hp (45.5 kW) @ 5000 rpm
Maximum Torque: 98 Nm (72.3 ft. lbs) @ 3000 rpm
Clutch System: Single-disc dry Clutch System: , hydraulically operated
Transmission type: 5 speed
Final Drive: Shaft
Starting: Electronic
CHASSIS SPECS
Frame Type: Three-section composite frame consisting of front and rear section, load bearing engine.
Suspension - Front: BMW Motorrad Telelever; stanchion diameter 35 mm, central strut , 144 mm travel
Suspension - Rear: Die-cast steel single-sided swinging arm with BMW Motorrad Monolever; WAD strut (travel-related damping), spring pre-load adjustable to continuously variable levels by means of hydraulic handwheel, 100 mm travel
Front Fork - Rake & Trail Angles: 33.5 / 184 mm (7.2 inches)
MISCELLANEOUS SPECS
Front wheel 3.50 x 16
Rear wheel 4.00 x 15
Tire - Front: 150/80-16
Tire - Rear: 170/80-15
Brakes - Front: dual 305 mm discs with 4-piston calipers
Brakes - Rear: single 285 mm disc with 4-piston calipers
DIMENSIONS
Overall - Length: 2370 mm (93.3 inches)
Overall - Width: 1120 mm (44.1 inches)
Overall - Height: 1340 mm (52.8 inches)
Seat Height: 790 mm (31.1 inches)
Fuel Capacity: 17.5 l
Dry Weight (without fluids): 245 kg (540.1 pounds)
ENGINE SPECS
Final Drive: Shaft
CHASSIS SPECS
MISCELLANEOUS SPECS
DIMENSIONS
