2016 Suzuki Hayabusa - Coolness Factor = 61.1%
Posted: Fri Nov 25, 2016 3:47 am
2016 Suzuki Hayabusa on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... yabusa.htm
2016 Suzuki Hayabusa on http://www.Totalmotorcycle.com
The Ultimate Sport, In Timeless Styling...
The Suzuki Hayabusa is quite simply the Ultimate Sportbike. Twist the throttle and it responds with awesome acceleration and crisp throttle response in every gear with an unbelievable top-end charge. Thanks to a lightweight and rigid twin-spar aluminum frame and state-of-the-art suspension, that performance is matched by equally impressive handling, providing exceptional control in tight corners, reassuring stability in sweeping turns and a smooth ride on the highway.
More than a decade ago, Suzuki developed a machine so unique that it instantly attracted a devoted following around the world. Like its namesake, the Japanese peregrine falcon, the Hayabusa is famed for cutting through the air with incredible agility and performance.
Through countless engineering refinements of the original design, the Hayabusa spirit has endured. The Hayabusa features Brembo Monobloc high-performance calipers and an Antilock Brake System*. Its incomparable performance delivers a fun and sporty ride at any speed, setting the bar high for rivals and defining the “Ultimate Sport Bike.” The radically original yet timeless styling also reflects the spirit of the person who owns a Hayabusa. Its sensational power, speed, smooth ride and overwhelming presence continue to fascinate owners and onlookers alike. Because the Hayabusa is, and always will be, the ultimate sport bike.
2016 Suzuki Hayabusa http://www.Totalmotorcycle.com Key Features
KEY FEATURES
Lighter and more rigid than conventional bolt-together calipers, the Hayabusa's top-of-the-line radial-mount Brembo Monobloc front brake calipers deliver better feedback to the rider. Piston diameter was enlarged from 32-30mm to 32-32mm. Larger pistons help apply greater force to the brake disc, which results in increased initial bite and a more controlled feeling
The standard equipment Antilock Brake System* (ABS) unit features a lightweight, compact design. The ABS enhances brake performance by helping prevent, to a certain extent, wheel locking due to changes in road conditions or excessive braking, by matching stopping power to available traction.
*The ABS is a supplemental device for brake operation, not a device for shortening stopping distance. Always remember to reduce speed sufficiently before approaching curves
2016 Suzuki Hayabusa http://www.Totalmotorcycle.com Features and Benefits
ENGINE FEATURES
1 Powerful 1340cc in-line 4-cylinder fuel-injected, liquid-cooled DOHC engine built to deliver a broad wave of torque for effortless acceleration.
Forged three-ring aluminum-alloy slipper pistons provide superior strength, while PVD-coated rings reduce friction and improve cylinder sealing.
The chrome nitride Physical Vapor Deposition (PVD) piston ring coating is harder and smoother than conventional chrome plating, reducing friction while improving sealing to the cylinder.
Suzuki Composite Electrochemical Material (SCEM) cylinder plating improves heat dissipation, durability and ring seal.
U-shaped cutouts in the cylinder-bore sides allow air pressure created by descending pistons to escape to adjacent cylinders to reduce internal pumping pressure and mechanical power losses.
Lightweight titanium valves allow use of light valve springs and high lift while maintaining accurate valve control.
Iridium spark plugs produce more complete combustion and last longer than conventional plugs.
Curved radiator with a compact, dense-core design and two ECM-controlled electric fans keep the engine temperature stable.
Suzuki Clutch Assist System (SCAS) serves as back-torque-limiting system for smooth downshifts and also contributes to a light clutch pull.
Close ratio, constant-mesh 6-speed transmission uses dedicated oil spray to the 4th, 5th and 6th gears to reduce friction, wear and mechanical noise during high-speed operation.
Suzuki's advanced fuel-injection system with tapered, 44mm double-barrel Suzuki Dual Throttle Valve (SDTV) induction improves combustion efficiency and smooth's throttle response.
Two 12-hole fine-spray injectors on each throttle body improve fuel atomization for better combustion efficiency while reducing fuel consumption.
Idle Speed Control (ISC) system improves cold starting and helps maintain stable engine idle under a variety of conditions.
Suzuki Pulsed-secondary AIR-injection (PAIR) system ignites unburned hydrocarbons (HC) and reduces carbon monoxide (CO) emissions.
Large-volume catalyzer in the twin-silencer exhaust permits high flow while further reducing HC, CO and nitrogen oxide (NOx) emissions.
2 Suzuki Drive Mode Selector (S-DMS) lets riders select engine power output to match preferences or riding conditions.
2016 Suzuki Hayabusa - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $14599 USD
Canada MSRP Price: $15399 CDN
ENGINE
Engine 1340cc, 4-stroke, liquid-cooled, 4-cylinder, DOHC
Bore x Stroke 81.0 mm x 65.0 mm (3.19 in x 2.56 in)
Compression Ratio 12.5 : 1
Fuel System Suzuki Fuel Injection
Starter Electronic
Lubrication Wet sump
DRIVE TRAIN
Transmission 6-speed constant mesh
Final Drive Chain, RK GB50GSV Z4, 114 links
CHASSIS
Suspension Front Inverted telescopic, coil spring, oil damped
Suspension Rear Link type, coil spring, oil damped
Brakes Front Brembo, Disc, twin
Brakes Rear Disc
Tires Front 120/70ZR17M/C (58W), tubeless
Tires Rear 190/50ZR17M/C (73W), tubeless
Fuel Tank Capacity 21.0 L (5.5 US gallons), 20.0 L (5.3 US gallons) CA model
Color Candy Daring Red / Metallic Mystic Silver, Metallic Thunder Gray / Glass Sparkle Black
ELECTRICAL
Ignition Electronic ignition (Transistorized)
DIMENSIONS AND CURB WEIGHT
Overall Length 2190 mm (86.2 in)
Overall Width 735 mm (28.9 in)
Wheelbase 1480 mm (58.3 in)
Ground Clearance 120 mm (4.7 in)
Seat Height 805 mm (31.7 in)
Curb Weight 266 kg (586 lbs)
KEY FEATURES
ENGINE FEATURES
ENGINE
Starter Electronic
DRIVE TRAIN
CHASSIS
Brakes Rear Disc
ELECTRICAL
