2017 Zero FXS - Coolness Factor = 59.7%
Posted: Fri Apr 07, 2017 4:58 am
2017 Zero FXS on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... ro-FXS.htm
2017 Zero FXS on www.Totalmotorcycle.com
Stealthily dice through any urban obstacle...
Ride the City. Rail the Track.
Whether you’re charging through the inner city supermoto style or indulging in backroad shenanigans, the new Zero FXS is ready to push the limits. Delivering a nearly instantaneous 78 ft-lb of torque, up to 46 hp and weighing less than 300 lbs, the Zero FXS is quick and agile. Suspension and brakes are ideally suited to the rigors of spirited riding, giving the rider greater control. 17-inch wheels and Pirelli Diablo Rosso II tires provide superior grip and corner control…for good reason: the throttle response is simply stunning. The Zero FXS takes supermoto to a new level. Think of it as supermoto on steroids.
No ride time is wasted thanks to its maintenance-free powertrain, and each mile covered costs only around a penny in electricity. The Zero FXS features an optional unique, patented modular power pack system that allows recharging either on or off the bike, making it ideal for the city. With advanced ABS, fully adjustable suspension, dual projector beam headlights, alloy wheels and high performance street tires, it’s ready to hit the supermoto track or turn formerly mundane tasks into thrilling rides.
2017 Zero FXS www.Totalmotorcycle.com Key Features
2017 Advancements
Upgraded Power Packs with a New Five-Year, Unlimited-Mileage Warranty
11% More Torque. 5% Increase in Power. Smoother Delivery.
Wider, Stronger Drive Belt
2017 Zero FXS - www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $8,495 to $10,995 USD
Canada MSRP Price: $10995 to $14,395 CAD
range ZERO FXS ZF3.3 MODULAR
City 45 miles (72 km)
Highway, 55 mph (89 km/h) 27 miles (43 km)
» Combined 34 miles (55 km)
Highway, 70 mph (113 km/h) 18 miles (29 km)
» Combined 26 miles (42 km)
Motor
Peak torque 78 ft-lb (106 Nm)
Peak power 27 hp (20 kW) @ 4,300 rpm
Top speed (max) 85 mph (137 km/h)
Top speed (sustained) 75 mph (121 km/h)
Type Z-Force® 75-5 passively air-cooled, high efficiency, radial flux, interior permanent magnet, brushless motor
Controller High efficiency, 550 amp, 3-phase brushless controller with regenerative deceleration
Power system
Est. pack life to 80% (city) 101,000 miles (163,000 km)
Power pack Z-Force® Li-Ion intelligent modular
Max capacity 3.3 kWh
Nominal capacity 2.9 kWh
Charger type 650 W, integrated
Charge time (standard) 4.7 hours (100% charged) / 4.2 hours (95% charged)
» With one accessory charger 2.1 hours (100% charged) / 1.6 hours (95% charged)
» With max accessory chargers 1.5 hours (100% charged) / 1.0 hour (95% charged)
Input Standard 110 V or 220 V
Drivetrain
Transmission Clutchless direct drive
Final drive 90T / 20T, Poly Chain® HTD® Carbon™ belt
Chassis / Suspension / Brakes
Front suspension Showa 41 mm inverted cartridge forks, with adjustable spring preload, compression and rebound damping
Rear suspension Showa 40 mm piston, piggy-back reservoir shock with adjustable spring preload, compression and rebound damping
Front suspension travel 7.00 in (178 mm)
Rear suspension travel 8.94 in (227 mm)
Front brakes Bosch Gen 9 ABS, J-Juan asymmetric dual piston floating caliper, 320 x 5 mm disc
Rear brakes Bosch Gen 9 ABS, J-Juan single piston floating caliper, 240 x 4.5 mm disc
Front tire Pirelli Diablo Rosso II 110/70-17
Rear tire Pirelli Diablo Rosso II 140/70-17
Front wheel 3.00 x 17
Rear wheel 3.50 x 17
Dimensions
Wheelbase 56.0 in (1,422 mm)
Seat height 32.9 in (836 mm)
Rake 24.4°
Trail 2.8 in (71 mm)
Weight
Frame 20 lb (9.1 kg)
Curb weight 251 lb (114 kg)
Carrying capacity 379 lb (172 kg)
Economy
Equivalent fuel economy (city) 530 MPGe (0.44 l/100 km)
Equivalent fuel economy (highway) 215 MPGe (1.09 l/100 km)
Typical cost to recharge $0.37
Pricing
Effective price after federal tax credit $7,645
(Additional government incentives may be available)
MSRP $8,495
(Does not include government incentives. Does not include local shipping, applicable taxes, PDI, or road registration fees.)
Warranty
Standard motorcycle warranty* 2 years
Power pack warranty* 5 years/unlimited miles
range ZERO FXS ZF6.5
City 90 miles (145 km)
Highway, 55 mph (89 km/h) 54 miles (87 km)
» Combined 68 miles (109 km)
Highway, 70 mph (113 km/h) 37 miles (60 km)
» Combined 52 miles (84 km)
Motor
Peak power 46 hp (34 kW) @ 4,300 rpm
Power system
Est. pack life to 80% (city) 203,000 miles (327,000 km)
Power pack Z-Force® Li-Ion intelligent integrated
Max capacity 6.5 kWh
Nominal capacity 5.7 kWh
Charge time (standard) 8.9 hours (100% charged) / 8.4 hours (95% charged)
» With one accessory charger 3.8 hours (100% charged) / 3.3 hours (95% charged)
» With max accessory chargers 1.7 hours (100% charged) / 1.2 hours (95% charged)
Drivetrain
Dimensions
Rake 24.4°
Weight
Curb weight 293 lb (133 kg)
Carrying capacity 337 lb (153 kg)
Economy
Typical cost to recharge $0.73
Pricing
Effective price after federal tax credit $9,445
MSRP $10,495
Warranty
range ZERO FXS ZF6.5 MODULAR
Motor
Power system
Drivetrain
Dimensions
Rake 24.4°
Weight
Economy
Pricing
Effective price after federal tax credit $9,895
MSRP $10,995
Warranty
2017 Advancements
Motor
Power system
Drivetrain
Dimensions
Rake 24.4°
Weight
Economy
Pricing
MSRP $8,495
Warranty
Motor
Power system
Drivetrain
Dimensions
Rake 24.4°
Weight
Economy
Pricing
MSRP $10,495
Warranty
Motor
Power system
Drivetrain
Dimensions
Rake 24.4°
Weight
Economy
Pricing
MSRP $10,995
Warranty
