#327: 2018 Indian Roadmaster Elite - Coolness Factor = 42.4%
Posted: Fri Jul 28, 2017 3:37 am
2018 Indian Roadmaster Elite on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... te-review/
The ultra-premium Roadmaster®Elite features custom-inspired two-tone candy paint with real 23K gold leaf badging on the tank and lowers.
This paint scheme takes 30 hours to complete and is finished by hand. The Roadmaster Elite comes standard with a large number of premium amenities including the industry-leading Ride Command system, a 300-watt premium audio system, passenger armrests, billet aluminum passenger and driver floorboards, a premium touring console, and pinnacle mirrors.
2018 Indian Roadmaster Elite Totalmotorcycle.com Key Features
Now You Can’t Say The Best Is Yet To Come.
2018 Indian Roadmaster Elite Totalmotorcycle.com Features and Benefits
his ultra-premium touring machine features custom-inspired two-tone candy paint that takes 30 hours to complete and is finished by hand. It’s even embellished with real 23K gold leaf badging on the tank and lowers.
2018 Indian Roadmaster Elite – Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $36,999 USD
Canada MSRP Price: $44,499 CDN
ENGINE
Engine Type
Thunder Stroke® 111
Displacement
111 cu in (1811 cc)
Bore x Stroke
3.976 in x 4.449 in (101 mm x 113 mm)
Compression Ratio
9.5:1
Electronic Fuel Injection System
Closed loop fuel injection / 54 mm bore
DRIVETRAIN
Primary Drive
Gear Drive Wet Clutch
Drive/Driven Clutch
Wet, Multi-Plate
Final Drive
2.2 : 1
PERFORMANCE
Peak Torque
119 ft-lbs (161.6 N m)
Peak Torque RPM
3000 rpm
GEAR RATIO (OVERALL)
1st
9.403 : 1
2nd
6.411 : 1
3rd
4.763 : 1
4th
3.796 : 1
5th
3.243 : 1
6th
2.789 : 1
SUSPENSION
Suspension: Front – Type/Travel
Telescopic Fork / 4.7 in (119 mm) – Cartridge Type
Front Fork Tube Diameter
46 mm
Suspension: Rear – Type/Travel
Single Shock w/Air adjust / 4.5 in (114 mm)
CHASSIS
Brakes/Front
Dual / 300mm Floating Rotor / 4 Piston Caliper
Brakes/Rear
Single / 300mm Floating Rotor / 2 Piston Caliper
Wheels/Front
Cast 16 in x 3.5 in
Wheels/Rear
Cast 16 in x 5 in
Tires/Front
Dunlop® Elite 3 130/90B16 73H
Tires/Rear
Dunlop® Elite 3 Multi-Compound 180/60R16 80H
Exhaust
Split Dual Exhaust w/ Cross-over
DIMENSIONS
Wheelbase
65.7 in (1668 mm)
Seat Height
26.5 in (673.1 mm)
Ground Clearance
5.5 in (140 mm)
Overall Height
58.7 in (1491 mm)
Overall Length
105.4 in (2676 mm)
Overall Width
39.4 in (1000 mm)
Rake
25°
Trail
5.9 in (150.0 mm)
Fuel Capacity
5.5 gal (20.8 l)
GVWR
1385 lbs (628 kg)
Weight (Empty Tank / Full of Fuel)
921 lbs / 953 lbs (418 kg /433 kg)
FEATURES
Color / Graphics
Cobalt Candy over Black Crystal w/23K Gold Trim
STANDARD
Standard Equipment
ABS; Cast Aluminum Frame with Integrated Air-Box; Cruise Control; Highway Bar; Keyless Ignition; Horizon Power Shield; Genuine Leather Seats; Remote Locking Hard Saddle Bags; Remote Locking Trunk; Tire Pressure Monitoring; 300 Watt Stereo with AM/FM, Bluetooth, USB, Smartphone Compatible Input, and Weatherband; Heated Rider & Passenger Seats; Heated Grips; Adjustable Passenger Floorboards; 36.2 Gallons of Storage.
ELECTRICAL
Lights
Pathfinder LED Lights (headlight, driving lights, turn signals, tail light trunk, tail light, trunk interior light, and headdress fender light.)
Gauges
Fairing mounted instrument cluster featuring analog speedometer and tachometer, with fuel gauge, range, odometer and current gear. 15 LED telltale indicators; cruise control enabled, cruise control set,neutral, high beam, turn signal, ABS, check engine, low tire pressure, battery, low fuel, security system, low engine oil pressure and MHP or km/h unit designation
Ride Command®
7″ Indian Touchscreen including realtime clock; ambient air temperature; heading; audio information display; vehicle trouble code readout; Vehicle Status (tire pressure, voltage, engine hours, oil change); Vehicle Info (speed, fuel range, RPM, gear position); Dual Trip Meters (fuel range, miles, average fuel economy, instantaneous fuel economy time, average speed); Ride Data (heading, moving time, stop time, altitude, altitude change); Bluetooth connectivity for phone and headset; Map/Navigation
ENGINE
Engine Type
Thunder Stroke® 111
Displacement
111 cu in (1811 cc)
Bore x Stroke
Compression Ratio
9.5:1
DRIVETRAIN
Primary Drive
Drive/Driven Clutch
Wet, Multi-Plate
Final Drive
2.2 : 1
PERFORMANCE
Peak Torque
Peak Torque RPM
3000 rpm
1st
9.403 : 1
2nd
6.411 : 1
3rd
4.763 : 1
4th
3.796 : 1
5th
3.243 : 1
6th
2.789 : 1
SUSPENSION
46 mm
CHASSIS
Brakes/Front
Brakes/Rear
Wheels/Front
Cast 16 in x 3.5 in
Wheels/Rear
Cast 16 in x 5 in
Tires/Front
Tires/Rear
Exhaust
DIMENSIONS
Wheelbase
65.7 in (1668 mm)
Seat Height
26.5 in (673.1 mm)
Ground Clearance
5.5 in (140 mm)
Overall Height
58.7 in (1491 mm)
Overall Length
105.4 in (2676 mm)
Overall Width
39.4 in (1000 mm)
Rake
25°
Trail
5.9 in (150.0 mm)
Fuel Capacity
5.5 gal (20.8 l)
GVWR
1385 lbs (628 kg)
FEATURES
Color / Graphics
STANDARD
Standard Equipment
ELECTRICAL
Lights
Gauges
Ride Command®
