Exhaust Pipe Temperature?
Posted: Tue Apr 09, 2019 1:50 am
by Onaramel
Anyone know the approximate (average) running temperature of the exhaust pipes and/or heat shields? I would like to powder coat the shields, the paint shop says they will easily hold up to 400 degress F as they bake it at that temp. Maybe I need to buy a new pipe? I play for real money on the gambling that I choose on this website [LINK REMOVED BY ADMIN] these guys write cool reviews and now I can spend money for my cycle.
THX
Re: Exhaust Pipe Temperature?
Posted: Wed May 22, 2019 2:31 am
by john_m4rsnall
I read that exhaust gas temperatures can be in excess of 1000 degrees C, but are typically about 800 degrees C.
Posted: Wed May 22, 2019 5:16 am
by NorthernPete
Ask the shop if they recommend their product for that application. If not, they should have some alternative for your project.
Posted: Wed Aug 21, 2019 8:35 pm
by brajon
The Rustoelum High Heat paint rated at 2000 deg F is a good product.
Posted: Fri Mar 05, 2021 12:17 am
by Sammyjonas6532
I love the way you write and share your niche! Very interesting and different! Keep it coming!
Posted: Sun Dec 17, 2023 8:10 pm
by polinkuer12
The approximate average running temperature of exhaust pipes and/or heat shields can vary depending on several factors such as the type of vehicle, engine, and exhaust system. However, in general, the typical operating temperature of exhaust pipes and heat shields can range from 300 to 900 degrees Fahrenheit (150 to 480 degrees Celsius). It's important to note that the specific temperature can be influenced by factors such as vehicle speed, engine load, and ambient temperature. Additionally, certain sections of the exhaust system may experience higher temperatures, especially closer to the engine or on sections where catalytic converters are located.
Quick Draw
Posted: Wed Mar 13, 2024 2:31 pm
by sarausa
good
Posted: Wed May 29, 2024 4:56 am
by Harper99
In automobile engineering, the temperature of the exhaust pipe is an important characteristic to keep an eye on. It displays emissions control, fuel economy, and engine performance. Effective management is essential to vehicle design and maintenance because it guarantees engine longevity and environmental responsibility.
