2007 Honda VT750C2 (Shadow Spirit) Cable lengths
Posted: Thu Feb 06, 2020 6:57 am
by jadoiron
I know this is likely a long shot, but I'm wondering if anyone here has ever attempted to swap the stock handlebars on an '07 VT750C2 out for a set of ape hangers (Specifically, 14 inch ones).
Right now it's in a shed (protected) in the middle of a Canadian Winter with the door frozen shut, and I'm trying to figure out if I should plan on having to get longer cables for the throttle, clutch, front brake...
Wondering if anyone has ever done this swap, or a similar one, and if the stock cables were long enough.
Thanks all!
Re: 2007 Honda VT750C2 (Shadow Spirit) Cable lengths
Posted: Thu Feb 06, 2020 10:31 am
by Gummiente
You will most definitely need longer cables and wire extensions if you plan on installing apehangers. If you're open to other options, a set of 4" pullback risers using the stock handlebars can usually be installed without changing cables and is a good alternative to apehangers. Where in Canada are you?
Posted: Fri Feb 07, 2020 4:20 am
by jadoiron
Gummiente wrote: Thu Feb 06, 2020 10:31 am
That seems to be the common answer. I guess I'll look into getting that done then. I don't know if I'd be quite up to the task myself, but will track down a kit at least. Might just bite the bullet and let the dealer do it. $$$
I'm in Prince Edward Island.
Posted: Fri Feb 07, 2020 5:48 am
by jadoiron
I guess the second part of my question would be exactly what kit(s) I need to purchase to do this. There are so many options out there and different lengths. Maybe I'm in over my head...
Posted: Fri Feb 07, 2020 7:31 am
by Gummiente
Go to
www.partscanada.com, scroll down to "Learn More", select "Catalogs", then select the "Street" catalog. There's a section in there on handlebars and risers, some of it is bike make and model specific.
Posted: Fri Feb 07, 2020 7:33 am
by jadoiron
Gummiente wrote: Fri Feb 07, 2020 7:31 am
Go to
Thank you!
Posted: Tue Oct 31, 2023 5:44 pm
by tommchris
The throttle cables typically have two parts: the push cable and the pull cable. The push cable is usually longer than the pull cable.
Uno Online
Posted: Sun Dec 08, 2024 9:48 pm
by carinamon
For the 2007 Honda VT750C2 (Shadow Spirit), if you're considering modifying the handlebars (for example, with ape hangers), you may need to replace or extend the throttle, clutch, and front brake cables. These components often need to be lengthened by a few inches depending on the height of the handlebars.
Posted: Tue Jan 21, 2025 10:16 pm
by JolieKeva
It sounds like an interesting project! While I haven't done this exact swap myself, I can share that typically when upgrading to 14-inch ape hangers, you'll likely need longer cables for the throttle, clutch, and front brake. The stock cables on most bikes, including the VT750C2, are usually not long enough to accommodate such a significant change in handlebar height.
