Front Cylinder misfiring, throwing flames from cobra pipe
Posted: Sat Oct 17, 2020 6:33 pm
Hello,
My 2000 vstar 650 is running like ****, seems like front cylinder is not running. The exhaust for front cylinder is popping, throwing flames out of cobra exhaust. When I try full throttle it stars to bog down as if fuel starvation, but new aftermarket fuel filter from oreily shows gas. Removed only front spark plug boot and bike still runs. Removed only rear spark plug boot and bike shuts off. Both spark plugs have spark, I checked. No air leaks, checked by spraying wd40 when at idle. Could it be front carb, maybe needs to be synched, bad gas? I just rebuilt and cleaned both carbs a few months ago and seemed to run fine for a while. I just want bike to run like it used to, like a bat outta hell.
Thanks for reading and any input would be greatly appreciated.
PS Is it normal for bike to still run after pulling spark plug boot from front plug versus bike shutting off when pulling only rear boot?
