Wondering what everyone uses to wash their helmet visors.
So far I've just waited until it rains, which actually works pretty well.
Is water and a cloth sufficient, or should I buy some plastic cleaner?
Helmet Cleaner
- Tricycle Squid
- Real Name: Jennifer
- My Motorcycle: ganabogini
- Regular
- Real Name: James
- Years Riding: 2
- My Motorcycle: 2012 Kawasaki Ninja
Re: Helmet Cleaner
We sometimes get acid rain. Most visor cleaner works here
- Tricycle Squid
- Years Riding: 2
- My Motorcycle: 2022 plastic AHB
Re: Helmet Cleaner
Using water and a cloth can be a simple and effective way to clean your helmet visor, but there are some things to keep in mind to ensure you don’t scratch or damage it. Here’s a quick guide:
1. Water and a Microfiber Cloth:
Water: Start by rinsing the visor with lukewarm water to remove loose dirt and debris. This helps prevent scratching when you start wiping.
Microfiber Cloth: Use a soft, clean microfiber cloth to gently wipe the visor. Microfiber is ideal because it’s soft and less likely to scratch the surface
Technique: Dab the cloth rather than scrubbing, especially if the dirt is stubborn.
2. Plastic Cleaner:
Specialized Plastic Cleaners: These are designed specifically for materials like polycarbonate, which most visors are made from. They clean effectively without harming the material or leaving streaks.
Anti-Fog and Anti-Scratch Coatings: Some plastic cleaners come with additional properties that help maintain the visor’s anti-fog or anti-scratch coatings, which could be beneficial.
Application: Spray the cleaner onto the visor and wipe it with a microfiber cloth in a gentle, circular motion.
2. Plastic Cleaner:
- Tricycle Squid
- Real Name: Kuiskj
- Years Riding: 2
- My Motorcycle: Sirius
Re: Helmet Cleaner
These are engineered to work effectively with polycarbonate, the material used to make the majority of visors. In addition to being powerful cleaners, they do not damage the material.
- Real Name: Karen Brewer
- Years Riding: 5
- My Motorcycle: Yamaha, Sniper
Re: Helmet Cleaner
I usually use bottled water that I get in bulk from https://bottledevents.com/, as well as a microfiber cloth. Works well for me; it removes pests and filth without itching. If it is especially stubborn, I let the water sit for a while before wiping. I haven't needed to use any special cleansers yet!
- Real Name: William Thomas
- Years Riding: 2
- My Motorcycle: Honda
Re: Helmet Cleaner
A microfiber cloth with warm water is usually enough. For tougher spots, a plastic-safe cleaner helps—just avoid ammonia-based products since they can damage the visor.Seticivere wrote: Wed Feb 21, 2024 10:28 pm Wondering what everyone uses to wash their helmet visors.
