Flat Tire prevention?
Posted: Thu Sep 08, 2005 3:09 pm
by XR650 Rider
Hey all,
I aint been on here in a while but Im back with a question. What is the best way to keep from getting a flat tire on the trail? Does that tire sealant goop work?? If so which one works best on a dirtbike? Or is it better to carry the stuff to replace a tube? Oh by the way... I finally got a dirtbike about 2 months ago. I was finally able to lay my old 3 wheeler to rest. I now have a 2003 Honda XR650R. She is reall fast. I can keep up with my buddies now... LOL. :laughing: Thanks for the feedback...
Posted: Thu Sep 08, 2005 5:23 pm
by Wizzard
Personally I have always been impressed with that green slime goop . It really works without damaging your tires .
Regards, Wizzard
Posted: Thu Sep 08, 2005 10:08 pm
by FreeRide
Just had my first experience using Slime. Had a flat front tire 2 wks. ago. Happended after I got home and went to ride the next day to find front tire flat as a pancake. I aired up tire and went flat in 6 min.
Then I bought Slime and followed directions and now tire is holding air. BTW, Before using Slime I checked the tire using soapy water and looking for leak bubbles and could find none. Even checked sidewall and valve. Anyway, i can recommend it but beware of some "off" brands. I understand it can cause the rims to rust.
Posted: Thu Sep 08, 2005 10:37 pm
by BuzZz
You can buy extra-thick, heavy-duty inner tubes at most bike shops that sell tires. Or you can spend big and get some Bib Mousse inserts, but they have lifespan and top speep limitations.
http://www.motorace.com/miva/merchant.m ... _Code=MTBM
Posted: Thu Sep 15, 2005 5:09 pm
by XR650 Rider
Those mouse things are to expensive and too limited. But does that green slime stuff really work?
Posted: Thu Sep 15, 2005 8:29 pm
by BuzZz
I don't like tireslime. It is messy and won't seal a hole much bigger than a thorn or nail puncture. Snake bites and tears will just spray slime all over your bike while you roll to a stop on your flat. But some guys like the stuff... personal choice....
Your probably best off with some thick tubes and adding a few more psi than normal. You can run slime in them or not, depending on your decision.
