Bent Handlebar?
Posted: Sat Sep 17, 2005 11:45 am
Is there anything I can do (easily) about a bent handlebar? Should I just try to find a replacement?
Matt
Matt
25 Years. 425 Million Readers. 54 years of Motorcycle Guides ∙ Reviews ∙ The friendliest motorcycle community on the internet!
https://www.totalmotorcycle.com/BBS/
Big vise, small propane torch, big hammermattwells wrote:I also bent my footpeg mounting bracket, and that is one thick piece of metal. I can't figure out how to get it straight.
Matt
You can try it this way, worse thing that will happen is it will break. Then you will definitely need a new one. Might as well try. I personally always replaced mine though, and I'm usually the type of person to try and fix and use every last bit out of parts.mattwells wrote:Should I use the same method (torch and fine hammer work) on the handlebar?
Don't use heat. Just use your muscles. NO HAmmer.........mysta2 wrote:new handle bars are cheap, old handlebars are cheaper. if you do bend them back use heat if at all possible, without it you will signifigantly weaken the metal.
