Aftermarket air filter id?
Posted: Sat Sep 17, 2005 5:13 pm
Hello all.
With the exception of my research into diy air filters (see post under that name) I've only dealt with stock paper filters, so this may be obvious to someone who rides newer bikes.
I've got a 76 honda cb750 with a dirty air filter, but it's been replaced (I think) with a different kind. There's no part no or manufacturer name I can see, but I'll try to describe it.
It consists of a chrome box with a perforated metal ring where the air gets through. On the inside is another, seperate ring held in place by a springy z-shaped piece of metal, and sandwiched in between the two metal rings is a dirty, crumbly foam ring, which I assume is covered in oil under all that crud. Cleaning it doesn't seem to be an option, since it disintegrates on contact, so I'd like to replace the foam, but I don't know what the heck it is. It doesn't look like the "uni" foam I've seen pictures of.
Any ideas?
Any ideas?
