Heel & Toe Shifter
alpeyton
Heel & Toe Shifter
#1 Unread post by alpeyton »
I have a Suzuki C50T, with heel / toe shifter. Had an unpleasant surprise with it the other day. I had just started off on an incline, still playing with the clutch friction zone, and when I picked up my left foot and set it on the floorboard, my boot heel hit the "up-shifter", and shifted it up to neutral. I was able to quickly stop, using the foot brake, and then start over again. I came close to dropping the bike. Lucky, no one was behind me.
So.....if you have a foot shifter, you might want to be aware of this little "possible", problem.
Al
Big Al
2005 Suzuki C50T
Bryson, TX
Meanie
#2 Unread post by Meanie »
No problem. Lower the heel lever just below the point of normal boot contact. Then, in order to shift, you have to lower the heel just a bit to shift. Of course, this is if you wear boots all the time. Works for me. I can rest my feet on any part of the floorboard without worrying about shifting.
Friends help you move. Real friends help you move bodies.
Keyoke
Years Riding: 22
#3 Unread post by Keyoke »
Cheers for letting us know! not having a bike woth footboards, wouldnt have picked this one up, myself....
Don't give up.
basshole
#4 Unread post by basshole »
I have a C50 and when I'm running up through the gears, I keep my left heel up just a bit and kinda feel my way around till I know my heel won't interfere with the heel shifter. It takes some getting used to but I like it.
Beer. Helping ugly people get laid since 1853
2006 Suzuki C50 Silver/Gray
embries
#5 Unread post by embries »
On my VSTAR1100 I ride with my toe forward (under the toe shifter) so then it's either slide the foot back for the heel shift, or lift the toe for a toe shift. Works very well for me.
jfeaz
#6 Unread post by jfeaz »
not relevant, but the c50 is a nice bike. i was about 2 minutes away from buying one until i opted for the v-star to save money.
