Page 1 of 4
**Winterization**
Posted: Mon Oct 03, 2005 2:23 pm
by BuzZz
For any and all interested parties, here is a very good article written by The Commander.... aka Mike, that details most all concerns you may have. Give it a read, it's worth it.
http://totalmotorcycle.com/maintenance/ ... torage.htm
Posted: Wed Oct 12, 2005 4:43 am
by rapidblue
good read I do have a questions though, since my bike is an old piece of sh@# and I am running premix (about 32:1) can I still use stabil and leave the gas/oil in the tank or do I have to do something different because of the premix?
Thanks
Posted: Wed Oct 12, 2005 6:36 pm
by BuzZz
You can just treat your pre-mix like straight gas. Stabilize away.....
Posted: Fri Oct 14, 2005 3:48 am
by rapidblue
right on
thanks
Posted: Tue Oct 18, 2005 8:56 am
by oldnslo
Winterize? My only acknowledgement of winter is to wear warmer riding clothes. Never, or nearly never snows or freezes in the vacation paradise where I live.
Posted: Tue Oct 18, 2005 1:45 pm
by flynrider
I can relate. Here in PHX winter is the time of year you can go out riding without fear of heat stroke. It's some of the best riding weather we get all year.
Posted: Tue Oct 18, 2005 8:14 pm
by BuzZz
Oh, "pee"-off, the both of ya's.
Your just jealous that you can't store your bike away for months while you sit there depressed and freezing your nuts off..... no wait, that's not right............
craap
Posted: Sat Oct 22, 2005 10:31 am
by oldnslo
A generous supply of strong alcoholic beverages helps you to at least think you aren't depressed, even if you are.
Posted: Mon Oct 30, 2006 11:16 am
by Shorts
Remove the spark plugs and pour a tablespoon (5 cc) of clean engine oil or spray fogging oil into each cylinder. Be sure to switch off the fuel before you crank the engine or else you may refill the drained carbs! Also, ground the ignition leads to prevent sparks igniting any fuel residue. Turn the engine over several revolutions to spread the oil around and then reinstall the plugs. Refitting the plugs before cranking the engine could result in a hydraulic lock if too much oil was used in the cylinder.
Ok, dumb question time - how do I crank the engine over without running it? I'm assuming this is manually cranking it, but how? Is it just a matter of spinning the rear tire? Or am I completely off?
Posted: Mon Oct 30, 2006 1:15 pm
by Sev
Hit the starter with no gas in the carbs?
