wet air filter...
Posted: Thu Oct 13, 2005 8:43 am
I am brand new to the forum and motorcycles. My brother called me a copule of weeks ago and said, "you want a motorcycle, I have one for you if you want it." I said sure. Now I am no mechanic but I like to tinker so I thought it would be a fun project. Turns out the thing hasn't been started in 9 years. I may have bit off more than I can chew. Its a 1982 Yamaha Maxim 400.
There was rust in the tank and the carbs/throttle wouldn't move. I took off the carbs and cleaned them out. When I had a key made I noticed there was considerable rust in the tank. Well I put in new gas and just tried to get it started. It did finally turn over. But I knew the tank and carbs needed more attention.
Since then I have taken off the carbs again and cleaned out the pilot jets (didn't do that the first time). I have also changed the oil and got the front brakes to work, they were all gummed up.
Now my question. when I got it fired up the first time I noticed that the air filter was moist. I suppose it could have been from a not so clean carb (pilot jets were still clogged). However is there a bigger problem that could cause fuel to blow back toward the air filter?
Thanks
Thanks
