Problem is no one seems to carry the 762 Bondo-Hair Long Strand Fiberglass putty, only the 272 Bondo-Short Strand Glass Reinforced Filler.
Is this short strand verison ok?
http://tinyurl.com/e4qnb
does the bondo fiberglass container come with everything i need or do i need to buy a separate, say, hardener? what are these tools you are warning me about, can i get them at the autoparts store as well?ronboskz650sr wrote:...your paddle or shaping tools.
Thanks for your help and sorry about the cardinals.... i thought or sure they had the best team in baseball this year. Maybe they can still pull it out, but it doesnt look good.ronboskz650sr wrote:BTW, I doubt glazing putty alon will give the the final surface you want before primer...probably need some body filler, too. Walmart sell plastic putty knifes in a set of three different sizes. I use
what the heck, if you think it can be done then who am i to disagree! its been rainy here in seattle but i hope it clears enough by this weenend for me to take this on. ill keep you posted, and thanks again for taking the time.ronboskz650sr wrote:Here's something you could try...Get your sanding done on high-build primer, until water stands on it and looks smooth. Find a single, non-metallic color you like, and go for it. When you get it all sanded out and buffed, sometimes little imperfections just make it look like a shiney old bike that's been weel worn. The high gloss makes it look great from a few feet away, only you now about the imperfections, and they add character while making the project a little easier, not worrying about perfect paint. Just an idea to keep it real.
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
