fuel tank
boomer
fuel tank
#1 Unread post by boomer »
I touched on the topic before about storing my biked in my dining room this winter,but can anyone tell me if my fuel tank still needs to be full or empty or partially full, I'm assuming the tank will be fine no matter how much gas is the tank since it will be stored in my living room which is climate controlled, no worries of moisture or water and so on ,am I correct on this, the only reason I can think of draining my tank is for safety reasons
mydlyfkryzis
Years Riding: 42
#2 Unread post by mydlyfkryzis »
Full tank minimizes condensation.
Also, put Stabil or other gas stabilizers in. It will help prevent the formation of gum and varnish.
Richard - Fully Dressed
Naked 1976 Honda CB360T
TechTMW
#3 Unread post by TechTMW »
I say empty it. Especially if the bike is older. Fuel vapors are nothing to play with. It's also a good thing to clean the fuel tank annually (If the bike is older) so this is a good opportunity for you to get all the old crap out of there.
jmillheiser
#4 Unread post by jmillheiser »
if its going to be indoors. Empty the tank, then run the bike until the gas is run out of the carbs
peterman
empty
#5 Unread post by peterman »
I say empty you dont' want those smells in your house. Also, I just bought a trank treatment kit called "Kreem". Its a three step process the final is a coating that prevents rust from forming. If you do this and store it empty you should have no problems with rust, especially if you're storing it indoors.
I got the treatment kit for $30 bucks at a local bike shop.
mydlyfkryzis
Years Riding: 42
#6 Unread post by mydlyfkryzis »
I somehow missed the"living room" part. :oops:
If you are in living space, empty it. Drain the carbs.
If you have any outside storage, I'd remove the tank and leave it outside. Wrapped up well, but not in living space. Even an empty tank will have gas vapors in it.
TechTMW
Re: empty
#7 Unread post by TechTMW »
peterman wrote:I say empty you dont' want those smells in your house. Also, I just bought a trank treatment kit called "Kreem". Its a three step process the final is a coating that prevents rust from forming. If you do this and store it empty you should have no problems with rust, especially if you're storing it indoors.
I've seen dozens of kreem jobs gone wrong, where the lining comes off and clogs your fuel system. If you are willing to eat the cost, get a por-15 treatment kit instead. If you are going to stick w/ the Kreem, follow the instructions CAREFULLY and BE PATIENT. If you screw up any of the steps, you too will have Kreem in your Carburettors ... :crazy:
paul246
Re: empty
#8 Unread post by paul246 »
Patience, that is the key. Kreem kits work, but you have to take your time and follow the instructions carefully. I have two tanks Kreemed that are still functioning perfectly after several years use.
I would remove the tank and store it outside, full of stabilized gas.
Honda XR650L Dual-Sport
9000white
#9 Unread post by 9000white »
drain the tank and the carburetors and spray 1/2 can of wd40 in tank.put the gas cap back on and forget it.
dr bob
Mustang
#10 Unread post by Mustang »
My heart goes out the riders that have to store their bikes.......I go more than 2 weeks without a ride and start to go stir crazy.
Of course the upside is that you don't have to worry about a Hurricane blowing it away, so there are always advantages and drawbacks I guess:):)
[b]Other Daily Reads[/b]
[url=http://bikerdiaries.blogspot.com/]Biker Diaries[/url]
[url=http://www.clutchandchrome.com]Clutch and Chrome[/url]
[url=http://totalmotorcycle.com/BBS/index.php]The motorcycle Forum[/url]
