Yamaha XJ650 Maixim Resurrection
Posted: Thu Oct 20, 2005 4:46 pm
Hi all - I'm working on a 1980 yamaha xj650G maxim. I finally fired it up again after years in the garage. I removed & cleaned the carbs before doing so, but it seems I have a few of the same problems I had years ago. It doesn't idle correctly, sometimes revs high for a long time, & back-fires often. Could this be due to the carbs not being synchronized? Something is also wrong with the throttle cable itslef, when I move the cable with my hand, it revs up. I had to remove it from the clip because at times when I'd turn the handle bars it would rev up then too...?? Any suggestions?
Thanks in advance.
Rj
Thanks in advance.
Rj
