2006. Honda Spirit 750 VS V-Star 650 Custom VS Vulcan 750
Posted: Sat Oct 22, 2005 6:46 pm
I think i've narrowed it down to these 3 bikes. I like the Yamaha a little better in the looks dept, but the Honda has more power for not that much money. Overall thoughts? Opinions? This is my first bike.
The Honda:
The Honda:
The Yamaha:ENGINE
Engine Type 745cc liquid-cooled 52-degree V-twin
Bore and Stroke 79.0mm x 76.0mm
Compression Ratio 9.0:1
Valve Train SOHC; three valves per cylinder
Carburetion Two 34mm diaphragm-type CV
Ignition CD with electronic advance, two spark plugs per cylinder
DRIVE TRAIN
Transmission Wide-ratio five-speed
Final Drive O-ring-sealed chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension 41mm fork; 5.1-inch travel
Rear Suspension Dual shocks with five-position spring-preload adjustability; 3.2-inch travel
Front Brake Single 296mm disc with twin-piston caliper
Rear Brake Drum
Front Tire 110/80-19
Rear Tire 160/80-15
DIMENSIONS
Rake 34-degree
Trail 152mm (6.0 inches)
Wheelbase 64.8 inches
Seat Height 26.6 inches
Dry Weight 496.0 pounds
Fuel Capacity 3.6 gallons, including 1.3-gallon reserve
OTHER
Emissions California version differs slightly due to emissions equipment.
Available Colors Black, Candy Orange, Titanium/Flame, Candy Dark Red/Flame
Model ID VT750DC
FACTORY WARRANTY INFORMATION
1 year Coverage of defects in materials and workmanship
For the Vulcan:Engine
Type 649cc, 40-cubic-inch, air-cooled, SOHC, 70° V-twin
Bore x Stroke 81 x 63mm
Carburetion (2) 28mm Mikuni downdraft-type
Ignition Digital TCI
Transmission 5-speed
Final Drive Shaft
Chassis
Suspension/Front Telescopic fork; 5.5" travel
Suspension/Rear Single shock, link-type, w/adjustable preload; 3.4" travel
Brakes/Front 298mm Disc
Brakes/Rear 200mm Drum
Tires/Front 100/90-19
Tires/Rear 170/80-15
Dimensions
Length 90.4"
Width 34.6"
Height 42"
Seat Height 27.4"
Wheelbase 63.4"
Dry Weight 474 Lbs.
Fuel Capacity 4.2 Gallons
Other
Warranty 1 Year (Limited Factory Warranty)
Engine: Four-stroke, DOHC, 8-valve V-Twin
Displacement: 749cc
Starting: Electric
Bore x stroke: 84.9 x 66.2mm
Compression ratio: 10.3:1
Cooling: Liquid
Carburetion: Keihin CVK34 x 2
Ignition: Electronic
Transmission: Five-speed
Final drive: Shaft
Frame: Double cradle, high-tensile steel
Rake / trail: 32 degrees / 5.0 in.
Front suspension / wheel travel: Hydraulic telescopic fork / 5.9 in.
Rear suspension / wheel travel: Air-assisted dual shocks with 4-way rebound damping / 3.5 in.
Front tire: 100/90x19 tubeless
Rear tire: 150/90x15 tubeless
Front brakes / rear brake: Dual discs / Drum
Overall length: 90.4 in.
Overall width: 33.5 in.
Overall height: 48.2 in.
Ground clearance: 5.9 in.
Seat height: 28.9 in.
Dry weight: 483 lbs.
Fuel capacity: 3.6 gal.
Wheelbase: 62.2 in.
Colors: Ebony / Candy Persimmon Red
*Specifications are subject to change.
Features
V-twin Engine with Gear-driven Balancer
- Optimum torque from idle to redline
- Smooth, reliable and easy to maintain
- Allows use of single-pin crankshaft without the heavy vibration
Four Valves Per Cylinder
- Better breathing for more power at high rpm
- Compact combustion chamber for increased compression ratio without detonation on today’s gasolines
- Boosts low-end torque
- Provides maximum valve area for optimum flow
- Hydraulic lash adjusters keep valves quiet with no adjustment required
Liquid Cooling
- Consistent operating temperatures, resulting in longer engine life
- Allows closer engine tolerances for more horsepower
- Automatic fan keeps things cool even in traffic
- Includes temperature gauge
Dual-stage Quiet Cam Chain
- Dual-stage design allows more compact cylinder heads
- Runs quietly, reliably
Automatic Cam Chain Tensioner
- Maintains precise timing without maintenance
- Assures greater reliability
Rubber-mounted Engine
- All but eliminates engine vibration
Five-speed Transmission
- Designed to handle the engine’s unique power characteristics
- The engine’s broad torque curve only needs five speeds for great acceleration and relaxed highway cruising
Positive Neutral Finder
- Just lift the shift pedal from first at a stop to easily find neutral
- A Kawasaki exclusive
Dual 34mm CVK Carburetors
- Precise fuel metering facilitates uniform power delivery at all engine speeds
- Quick throttle response
Handlebar-mounted Choke
- Hassle-free starting and warm-up
Air-assisted Rear Shocks with 4-way Rebound Damping
- Adjustable for a wide range of rider and passenger weights
- Provides a smooth and well-controlled ride
- Integral adjusters make it easy to tune the suspension for a particular riding style or road conditions
Shaft Drive
- Reliable and quiet, low-maintenance system
Dual Front Disc Brakes
- Reliable stopping power under demanding conditions
Speedometer and Instrument Cluster with Turn Signal Indicators and Caution Lamps
- Provides important information at a glance
- Compact design complements the bike’s clean look
Transistor Controlled Breakerless Ignition (TCBI) with Electronic Timing Advance
- A hot spark at all engine speeds for easy starting, smooth running and good fuel economy
